headlight motors
headlight motors
ok guys , my headlight motor( this particular one works when it wants to, goes up and down sometimes when i push the switch, but will go down if i flip the switch enough times. Well, as of late, now it'll close, but it'll keep on going, and wont stop until i grab ahold of the manual flipper, or i unblock the wiring to it.
why does it do this, and do i need a new one
my car is a 95 with 66k on it.
Re: headlight motors
ok that sounds confusing, what i mean to say is, the motor jsut keeps running, even after the headlight has gone down all the way. that particular headlight/motor have given me problems before.
It's your gear inside the motor. You can buy a plastic gear on E-bay for $15.00 or so or you can buy a metal one (which I highly recommend) for about $35.00. It is by far cheaper to replace the gear and not the whole motor.
ChrisFrez
02-15-2015 08:12 AM
