Header bolt fell out! - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 07-17-2014, 05:22 PM   #1
So one of my middle header bolts fell out and I drove the car for about 10-15km. I think it's a fiberglass gasket. I put the header bolt back in, and it still sounds like an exhaust leak. Did it maybe burn the gasket up while it was loose? Also number one Cyclinder header bolts were loose aswell.
Greg88 is offline   Reply With Quote
Old 07-17-2014, 07:50 PM   #2
parkers Z28's Avatar
Re: Header bolt fell out!
I would replace the header bolts when you replace the gasket
parkers Z28 is offline   Reply With Quote
Old 07-17-2014, 08:40 PM   #3
I already replaced the bolt and it's still ticking
Old 07-18-2014, 01:04 AM   #4
you probably burnt the gasket. just replace it. You need to re-torque header bolts after a few heat cycles of initial install......and not a bad idea to check them periodically
Chimera96 is offline   Reply With Quote
Old 07-18-2014, 02:27 AM   #5
If you put a bit of teflon tape around the threads they won't back out quite as easily.
97WS6SCharged is offline   Reply With Quote
Old 07-18-2014, 10:14 AM   #6
Super Moderator
Use good gaskets (Fel-Pro 1406) and good bolts (ARP) to minimize the problems. The stuff that comes with a set of headers is usually poor quality.
Injuneer is online now   Reply With Quote
Old 07-18-2014, 12:10 PM   #7
Ok thanks guys!
Old 07-19-2014, 08:59 AM   #8
Ok I have pacesetter headers and afr heads. They have the mr gasket gaskets which the ports are round and they have the fel pro ones that are square. All 1 1/2". Which do I go with?
Old 07-21-2014, 10:45 AM   #9
RUDEDOG is offline   Reply With Quote
Old 07-21-2014, 04:36 PM   #10
Super Moderator
The Mr. Gasket CopperSeal are also available in D-port #7154
Old 07-21-2014, 06:16 PM   #11
I used a set of Stage 8 locking bolts and never had the problem again....
bw_hunter is offline   Reply With Quote
Old 07-25-2014, 10:31 PM   #12
So my local auto parts store ordered me fel pro 1404 gaskets not the 1406, wil they still work?
Old 07-26-2014, 02:35 AM   #13
Fatdog2's Avatar
After market headers have to be tightened at least once a year.Got this from a a master mechanic.Hope this helps.
Fatdog2 is offline   Reply With Quote
Old 07-26-2014, 08:31 AM   #14
Quote:
1404 are the standard SBC port shape, the 1406 are the D shaped port shape that your engine has. They'll bolt up but I think there will be gasket material sticking into the port. Why not get the right ones?
Old 07-27-2014, 06:18 AM   #15
Yea I took the 1404 ones back and got the right ones yesturday! Thanks guys
Reply
Thread Thread Starter Forum Replies Last Post
FS: '94 Camaro Z-28, Black, 850hp, Blown 396, 9.5@143 RUENUF South Atlantic 4 03-13-2016 04:39 PM
header gaskets, and getting headers coated 94Z28LS1toLT1 General 1967-2002 F-Body Tech 8 04-07-2015 06:37 AM
92-95 ICM with MSD Blaster coil maybe2fast Parts For Sale 11 03-16-2015 10:45 AM
Crank hub fell off with supercharger pulley, options? cyteone LT1 Based Engine Tech 7 02-07-2015 07:04 PM
Why not a new Chevelle? SavageZ28 Automotive News / Industry / Future Vehicle Discussion 17 07-15-2002 12:04 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
