Gear for oil pump drive
Took the intake off the Z28 I just bought that had lost it's oil pressure. The gears on the shaft are mostly gone or chewed up. I had read that when the cam is change that this can happen. Wanted to know what kind of gear replacement you guys recommend? Thanks in advance.
Re: Gear for oil pump drive
you lucked out. hopefully they didn't run it too much and do any real damage.
http://cgi.ebay.com/ebaymotors/LT1-L...Q5fAccessories
I would try and find out more information on the motor,,how many miles are on it..IMO I would pull it out and open it up and find out if there is any more damage..It does not take much to smoke a bearing in these motors.How long has it been since the cam swap?
Not sure, I am going to put a new gear in it and see what happens. When I bought the car it was started and sounded great. I believe he parked the car once the problem started, been sitting 3 months. Going to put it in and keep fingers crossed.
Aftermarket cams can be made with different rear gear materials, some cause problems or need special "distributor" gears others work just fine with the stock drive.
The drive wearing out is usually caused by too much oil pump load from a high volume pump or really thick oil or by a cheap cam with the wrong gear material.
Not long ago one popular vendor sent out cams that would eat the oilpump drive gear in a matter of a few hundred miles, when it happened once it can be called a fluke, when it happens again in 300miles that is the wrong parts.
The mounting tab on mine cracked so I just made a custom one from a summit sbc billet gear drive just cut it down to size and welded a billet tab on it I dont have to worry about it getting cracked which is a more common problem than you would think i pulled the gear drive from my buddy's motor when he rebuilt it and his had the same crack along with 2 other buddies of mine. It also come with the bronze gear Ive got pics of it in my photo album if you wanna check it out.
