Update on my V8 swap, still no start...
Old 01-25-2008, 06:49 PM
JooneJune's Avatar
1994 LT1 Motor
1994 LT1 Tuned PCM
1994 Engine Harness
08/1993 Dash Harness
1995 3.4L Chasis
So heres the problem I had, after putting in the motor i had no fuel prime or spark of anykind. The fix: I had a 1995 Dash harness and a 1994 Engine harness, I purchased a "1994" harness from a board member who owns a scrap yard. When I called him he told me it was out of a 3.4L made in 08/93. My question is: That is considered a 1994? or still a 1993...
After hooking it up, i still have no prime. BUT! i forgot to plug in the connector behind the driver that controls the fuel pump and ABS.
-If I am not mistaken if the PCM sends a signal to the relay, and the relay doesn't send a signal from the pump the vehicle will not start... correct?
-is the 08/93 (has a 12 PIN ALDL) dash going to work with my 94 harness?
thanks in advance, i can't wait to get this Z up and running!
JooneJune is offline
Old 01-25-2008, 09:17 PM
JooneJune's Avatar
Hmnnn...
welp, I checked my brothers '94 3.4L (not the one I am doing the swap on) and his dash harness has a 12 pin ALDL... i suppose 08/93 is a "1994".
Old 01-25-2008, 09:28 PM
Green96Z's Avatar
The ALDL connector wasn't changed to 16 pin until 95.
Green96Z is offline
Old 01-26-2008, 09:03 PM
JooneJune's Avatar
Okay, so then it is possible that because there isn't a signal comming from the pump to the relay (Because i forgot to plug in the connector behind the driver) it's safe to say the PCM isn't going to allow the vehicle to start... Lemmie go plug that PITA in...
Injuneer
04-25-2022 06:22 PM
08-24-2015 06:41 AM
cmsmith
08-20-2015 07:57 PM
Boss002
07-24-2015 10:47 AM
Boss002
07-09-2015 03:33 PM
Quick Reply: Update on my V8 swap, still no start...
