fuel injectors
Old 10-05-2015, 02:51 PM
plattted's Avatar
fuel injectors
What is the O H M specs for fuel injectors on a 1994/ 5.7L engine?
plattted is offline
Old 10-05-2015, 05:22 PM
Re: fuel injectors
12 ohms
shoebox is offline
Old 10-06-2015, 06:38 AM
plattted's Avatar
Re: fuel injectors
Thank you for the reply.
Is 2 OHMs above or below that 12 OHMs allowed as a variable?
plattted is offline
Old 10-06-2015, 07:06 AM
maybe2fast's Avatar
Re: fuel injectors
I think the range is 12-17ohms. Typically you want them close to each other
maybe2fast is offline
Old 10-06-2015, 09:05 AM
plattted's Avatar
Re: fuel injectors
I have 6 that range 14.2-14.3.
One at 14.6.
One at 13.7. Just wondering if I should change the 14.6 and the 13.7 injectors. I tried cleaning them but these two remain out of range from the rest in spite of the cleaning. Recently I installed new lifters and plugs but still have a minor misfire/rough at low speeds and wondering if this could part of my problem.
Ted
plattted is offline
Old 10-06-2015, 10:35 AM
Re: fuel injectors
IDK (not an expert on this), but I would not consider that significant.
shoebox is offline
Old 10-06-2015, 05:04 PM
Re: fuel injectors
The 94 shop manual writeup for DTC 18 indicates that a resistance below 11.6 ohms is considered a faulty injector. As I recall, the upper limit is about 16 ohms.
Injuneer is offline
Old 10-07-2015, 09:24 AM
maybe2fast's Avatar
Re: fuel injectors
I agree with the Gents above, not the problem
Old 10-09-2015, 02:07 AM
97WS6SCharged's Avatar
Re: fuel injectors
One at 14.6.
Ted
You're talking about half an ohm difference. With OBD1 technology that is not enough to make a difference. If you take any set of injectors and ohm them they will not all read the same. The injectors seem to be within acceptable tolerances; if you're going to diagnose your misfire you really need to have a scanner handy to see what the PCM is doing when the mishap occurs. Otherwise you're just grasping at straws.
97WS6SCharged is offline
Old 10-09-2015, 06:29 AM
plattted's Avatar
Re: fuel injectors
Scanner,YES, that's the thing to use!
Thanks, Ted
plattted is offline
Old 10-09-2015, 07:20 AM
Re: fuel injectors
If the injectors or the wiring were outside of electrical spec, the PCM would have set DTC 18. That one does not turn on the SES light.
Injuneer is offline
Old 10-10-2015, 03:15 PM
plattted's Avatar
Re: fuel injectors
I'll continue my diagnosis...
plattted is offline
Old 09-23-2016, 11:30 PM
Fatdog2's Avatar
Re: fuel injectors
Would this be the same for the 93? I measured my injectors today and they read like this.
#8 cyl.-13.2
#6 cyl.-13.2
#4 cyl.-13.2
#2 cyl.-13.2
#7 cyl.-13.3
#5 cyl.-12.8
#3 cyl.-13.1
#1 cyl.-13.2
So the pass side seems steady but the drivers side seems to vary some.I'm getting ready to pull all the injectors for cleaning and new gasket (o-rings) install and was wondering.Many thanks in advance.
Fatdog2 is offline
Old 09-24-2016, 01:03 AM
Re: fuel injectors
The inrush of current develops the magnetic field that opens the injector. The resistance affects how fast the injector opens, but once it's open, resistance is no longer a factor. Lower resistance means higher current. Higher current means faster opening. But you don't want the resistance so low that the current excedes the amp capacity of the injector driver in the PCM.
In practice, the tiny change in opening speed due to differing resistance has very little impact on the amount of fuel injected. Impact is greatest at idle. Voltage also affects current, and the system voltage is likely to have a larger effect on the rate at which the injector opens, but the offset table compensates for that.
Bottom line after all the jumbo-jumbo - don't worry about the small differences in resistance.
Injuneer is offline
Old 09-24-2016, 08:37 AM
Fatdog2's Avatar
Re: fuel injectors
Again, great info.Thanks.
Fatdog2 is offline
Quick Reply: fuel injectors
