Whats needed for an cam install on an LT1?
Old 11-17-2006, 01:38 PM
94_PatriotRed_Z's Avatar
What is needed to do a cam install on an LT1?? and what are some brand names of each part??
I know I need a cam, springs, pushrods, and a gasket set, is there anything else?
Thanks in advance,
Kevin C
94_PatriotRed_Z is offline
Old 11-17-2006, 02:42 PM
seawolf06's Avatar
Do some searching in this forum and you'll find what you need. You may need to be specific.
Comp cams and Felpro should have most everything you'll need. Call them and see what they recommend. You should probably decide what cam you want first, then everything else will depend mostly on that, and your budget. Good luck.
seawolf06 is offline
Old 11-17-2006, 04:38 PM
ev95355's Avatar
I'ts not a bad job, i put my comp 305 in myself. Crane has an LT1 kit that comes with springs shims retainers and locks for $150 its a good deal and its good to .600 lift. Once you remove the hood latch mechanism the cam just barely has clearence to make it out. this setup of cam and springs alone took five tenths off my 1/4 time and i picked up 6 mph. Send me a PM if you have any questions.
ev95355 is offline
Old 11-17-2006, 04:43 PM
Alex607's Avatar
I put the lt4 hotcam in my car, 1.5, Easy to slide in, changed the rods, runs excellent.
Alex607 is offline
Old 11-17-2006, 06:10 PM
JoeliusZ28's Avatar
ive done a lot of searching for the same thing and have yet to find a solid listing. especially with brands/part numbers. IMO, i think a lot of the good cam threads of past have been purged from this forum. I just seem to remember more data being availible here back when i joined.
off the top of my head though (and im still looking for this info myself):
-cam
-rockers
-lifters(possibly reuse)
-timing chain, gears if youre going big
-springs
-retainers and locks (???)
-valve cover gaskets
-intake gasket
-timing gasket
-new fluids (oil for break-in, new coolant)
....im sure im missing about a dozen things.
JoeliusZ28 is offline
Old 11-18-2006, 10:26 AM
seawolf06's Avatar
http://shbox.com/ci/cam_install.html
Timing gears and chain should be changed as a set. If you're cam is big enough, you'll also need new injectors. Don't forget the tune, pushrods, guideplates, rocker studs and headers.
Queens94z28
12-20-2014 09:11 PM
F(ast)-body
02-26-2003 09:05 AM
GigaMp3z
02-20-2003 02:57 PM
NED4SPD
09-16-2002 10:45 PM
mjcent922
07-27-2002 12:42 PM
Quick Reply: Whats needed for an cam install on an LT1?
