FAST EFI as piggy back with stock PCM
Old 03-26-2015, 11:22 PM
TT350's Avatar
I have a FAST EFI setup with a crank trigger setup. I was thinking of taking the spark and fuel away from the stock PCM and let the FAST handle that and let the stock pcm take care of the rest. Has it been done before?
TT350 is offline
Old 03-27-2015, 08:29 AM
Re: FAST EFI as piggy back with stock PCM
Will the FAST accept input from the cam position sensor in the Opti?
Injuneer is online now
Old 03-27-2015, 08:33 AM
james007moore's Avatar
What is your set up ? I have that on my LT1..
James
james007moore is offline
Old 03-27-2015, 08:34 AM
TT350's Avatar
No, It's an older system.
I'm going to mount a flying magnet wheel on the hub.
Set up? what do you mean?
TT350 is offline
Old 03-27-2015, 10:33 AM
With only a crank position, won't you be limited to batch-fire injection and waste-spark ignition?
Can the FAST run the MAF, or is it speed-density only?
What functions do you want the stock PCM to perform? ....emissions? ...fans? ....speedo? ..... fuel pump? .....tach? Unless you parallel certain sensors to both systems, and with no injectors, ICM, etc. connected the stock PCM is going to be so loaded with codes a lot of subsystems will be disabled.
Old 03-27-2015, 11:29 AM
TT350's Avatar
The only sensors it will share with the fast will be the TPS. All others sensors I can add just for the fast.
The fast runs a MSD box and I would be using the stock distributor to point out the cylinders only.The fast is a batch fire system. They work great. I had a street car that ran 5.60's with this system.
TT350 is offline
Old 03-27-2015, 01:20 PM
The only sensors you can "share" are the three wire sensors. The two wire sensors like the CLT, AIT, etc. have to be paralleled. What about MAP? That can be paralleled.
Will the FAST drive a stepper motor IAC?
I run a MoTeC M48 Pro in parallel with my stock PCM. Stocker handles the the speedo, stock tach (which isn't very useful for a 7,000+ RPM application), and the stepper motor IAC. I have dual 2-wire sensors for CLT and IAT.
The MoTeC has the advantage of accepting the incredibly accurate optical cam position signals from the Opti, and using that info for full sequential injection, and an add-on 8-channel ignition driver using the LS1 coils.
Runs speed density, open loop (O2 sensors don't like leaded fuel), no knock sensor (solid roller cam). Speed-density requires development of an accurate VE table..... lot's of time on the dyno, with verification in the field.
Old 03-31-2015, 07:44 PM
TT350's Avatar
The only thing I need to share with the stock PCM is the TPS. It wont know its not in control for the most part.
TT350 is offline
DirtyDaveW
12-01-2016 05:37 PM
10-31-2016 11:09 AM
AlaskaZ28
01-01-2015 12:30 PM
birdblack
12-30-2014 06:59 PM
Queens94z28
12-20-2014 09:11 PM
Quick Reply: FAST EFI as piggy back with stock PCM
