Fan kick on temperatures?
Old 07-31-2015, 06:15 PM
4586's Avatar
Downloaded a bin from Fbodytech.com for a street rod with a 95 Lt1 driveline.
Using an OTC Nemysis datastream the cars temp is approaching 190 F and the fan is not triggered. A10 and A11 OFF
Studying the bin the trigger temps they are 95 degrees C (203 F) low speed and 104.75 C (220 F) high speed.
Are these temps correct?
4586 is offline
Old 07-31-2015, 07:24 PM
timnfxr's Avatar
Re: Fan kick on temperatures?
Stock fans turn on temps are: 226F (low speed), and 235F (high speed).
timnfxr is offline
Old 07-31-2015, 09:14 PM
Thirim's Avatar
I'm a little north of New York ... (Nova Scotia, Canada) .. very similar temps to NY.. I like 180deg thermostat and 195/205 for fan settings. (not worried about smog testing).
If you have AC, the AC should trigger the secondary fan when on regardless of temp I do believe.
Thirim is offline
Old 07-31-2015, 10:04 PM
4586's Avatar
I live about 800 yards from Canada!
Have the 95 Camaro LT1 driveline in a 37 Chevy sedan so smog isn't a concern. Which thermostat is stock for this LT1? Would like to try the 195/205 range.
No A/C...but thinking about a manual over ride for the fan (my next question).
Thanks Guys...
4586 is offline
Old 07-31-2015, 10:27 PM
Stock t'stat is 180*F. Most popular replacement is 160*. Fan temps could be set in the 185/195 range. Couple that with a couple degrees more ignition advance, for a HP gain.
Shoebox has a diagram for wiring a manual fan switch.
Injuneer is offline
Old 07-31-2015, 10:33 PM
4586's Avatar
Thanks for the info...will be doing some adjusting.
4586 is offline
Old 08-02-2015, 09:47 AM
4586's Avatar
OK..built the manual over ride switch with LEDs (ShoeBox diagram). Work great, click left, left LED on and low speed fan, click to the right, fan speeds 1&2 and both LEDs are on.
Looking at the diagram it appears that the LEDs will activate as the PCM supplies signal grounds even with manual switch off (in center position) which is OK with me.
Will this combination affect any DTC's?
Thanks all..
4586 is offline
Old 08-02-2015, 11:10 AM
Thanks all..
Yes, the LEDs will act like tell-tale lights when the switch is not in use (I actually have them on my car, but with no switch). If wired like the diagram, PCM operation of the fans is not affected.
shoebox is offline
Old 08-02-2015, 11:33 AM
Are the DTC's only a problem with OBD-II PCM's?
Injuneer is offline
Old 08-02-2015, 01:45 PM
I has one code for fan relay control circuits and II has two codes (one for relay 1 and one for relays 2 and 3).
shoebox is offline
jerrysims71
08-15-2015 12:47 PM
08-05-2015 08:35 AM
michael42869
Parts Wanted
08-03-2015 10:22 AM
Jmj93z28
07-08-2015 10:01 PM
Jmj93z28
07-08-2015 06:58 AM
Quick Reply: Fan kick on temperatures?
