Fan direction on a 97 lt1
Old 04-12-2014, 07:56 PM
bman101's Avatar
What direction does the cooling fans rotate as i am installing them off a toggle switch....if i an sitting in the drivers seat and could see them i think they should be running clockwise....any thoughts ????
bman101 is offline
Old 04-12-2014, 08:48 PM
Andrew88ZT56's Avatar
Re: Fan direction on a 97 lt1
Whichever direction results in air being pulled from the front of the radiator towards the rear. In other words, air should be pushed from the blades towards the fan motor.
Andrew88ZT56 is offline
Old 04-12-2014, 09:20 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
The fans on my 98 go CCW when viewed from the rear.
GaryDoug is offline
Old 04-13-2014, 11:03 AM
bman101's Avatar
so if i read this right.....pulling air through means that if I put my hand behind the fan(between the fan and block) the fans should be blowing towards my hand.....correct?????
bman101 is offline
Old 04-13-2014, 11:15 AM
timnfxr's Avatar
Correct... It's the same as the airflow while driving.
timnfxr is offline
Old 04-13-2014, 11:29 AM
bman101's Avatar
cool thanks...I will re wire as mine is blowingthrough the rad. and my coolant temp has been somewhat erratic after waterpump install
bman101 is offline
ChrisFrez
01-18-2015 08:05 AM
ChrisFrez
01-11-2015 03:47 PM
ChrisFrez
01-04-2015 08:43 AM
ChrisFrez
12-28-2014 02:25 PM
07-04-2005 05:00 PM
Quick Reply: Fan direction on a 97 lt1
