EVAP Canister Purge Solenoid Valve
Ok, this is my latest endeavour.
From reading the service manual, it looks like my rich condition could be stemming from the solenoid not receiving power or being stuck open, constantly purging the manifold, in essence drawing extra fuel into the picture. Sounds reasonable, especially since I've checked EVERYTHING else.
Unfortunately, the service manual doesn't specify a testing technique. Does anyone know of one?
All it does is draw in fumes from the tank. I don't think it is going to cause a rich condition (or not much of one). If there was a problem with the EVAP solenoid, you would probably get a code.
Well, it's on a 93, so there's no code that I can find for it. That's going down the list of codes in the service manual too.
It seems that it could be my problem, since when the car is initially started, it's fine, and as it warms up, the fuel load up begins, just like stated in the service manual text.
If it's not, I'm going to be wedged in between two very big immobile rocks.
Re: EVAP Canister Purge Solenoid Valve
I am getting this code...does that mean the solenoid needs replaced? The wiring all around it looks fine. Mods in sig, I thought I heard somewhere that if you dont have your AIR/EGR then it might disrupt the EVAP.
-Dustin-
-Dustin-
-Dustin-
-Dustin-
Thank you I ordered a solenoid, since I checked the wiring and connections. It wouldnt be the canister would it? Thanks again shoebox.
-Dustin-
-Dustin-
14
08-11-2015 12:03 PM
