Equipment removal question
Old 08-03-2016, 08:17 PM
vicki711's Avatar
I have a 95 z28 I removed the air pump and sensors as well as the evap sensor...do I need to keep the sensors plugged in even know I'm not using what they control?
vicki711 is offline
Old 08-03-2016, 09:27 PM
Re: Equipment removal question
What sensors? EVAP does not have a sensor, it has a solenoid. What is the reason for removal of these things? Trouble codes will follow for most items.
shoebox is offline
Old 08-03-2016, 09:39 PM
vicki711's Avatar
Be everything involved with the evap sys and air pump
vicki711 is offline
Old 08-04-2016, 10:15 AM
The EVAP system recycles collected fuel vapor. Keeps the back end of the car from stinking of gasoline. Doesn't hurt performance in any way. Neither does the AIR system.
As Rob indicated, there are no "sensors" associated with either system, so it appears you deleted the systems without knowing the details of what you were doing or why???
Injuneer is online now
DETROIT_AREA_00_SS
08-20-2016 01:44 PM
4586
07-31-2015 06:03 PM
97TA-WS6-Con
09-05-2002 02:26 AM
ROCKN SS
08-11-2002 07:35 PM
kraka
03-29-2002 05:33 PM
Quick Reply: Equipment removal question
