Engine banging at start up
Old 01-31-2015, 12:50 PM
kksi's Avatar
Hi:
My 94z LT-1 has a mild to moderate banging at start up in cold weather but after 15 seconds or so it disappears. Im not a mechanic but it doesnt sound like a valve tap, something deeper. Is this something to worry about?
Like I said after about 15 seconds or so the banging stops and drives and sounds great.
Thanks for your input.
kksi is offline
Old 01-31-2015, 02:59 PM
87Aerocoupe's Avatar
Re: Engine banging at start up
What's your oil pressure look like, is it low, if so could be a bearing going bad?
87Aerocoupe is offline
Old 01-31-2015, 03:19 PM
kksi's Avatar
It seems fine during normal driving conditions. When Idling it approaches the red line but Im thinking it has always done this and then when accelerating it goes back to normal.
kksi is offline
Old 01-31-2015, 03:42 PM
bw_hunter's Avatar
It sounds like a bad bearing. Yes, it's something to worry about. If it's a heavy sounding knock...like a big hammer hitting an anvil, it's probably the mains.
bw_hunter is offline
Old 01-31-2015, 05:38 PM
kksi's Avatar
Its more of a mild to moderate sound. Is there a way to diagnose it or am I at the mercy of the garage and their diagnosis?
kksi is offline
Old 01-31-2015, 05:55 PM
lt1-xjs's Avatar
If it does it first thing in the morning and then goes away, doesn't do it any more till the next day, It's likely piston slap and yes it is common.
lt1-xjs is offline
Old 01-31-2015, 09:31 PM
What viscosity oil are you using? What is the ambient temperature when this happens?
Injuneer is offline
Old 01-31-2015, 09:41 PM
grabbem88's Avatar
Mine's been doing that since 170k or so and I thought was from oblong cast pistons but I never hear after 10 minutes of running
I've been running on borrowed time for a looooong time lol
grabbem88 is offline
Old 01-31-2015, 10:16 PM
Post some audio of the noise. Near impossible to diagnose a noise without being able to hear it.
shoebox is offline
Old 02-04-2015, 11:34 AM
maybe2fast's Avatar
audio or video is required
maybe2fast is offline
Old 02-04-2015, 02:10 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Badly worn crankshaft bearings will get noisier with hotter engine and oil. i.e. Quietest when cold, loudest when hot (especially when accelerating). Not likely in your case.
GaryDoug is offline
Old 02-04-2015, 04:05 PM
Chimera96's Avatar
a "guess" based on Op's description is piston slap. some experience this and have for several years
take a close look at oil and cut open filter ...if "sparkles"...than bearings
Chimera96 is offline
Old 02-04-2015, 04:42 PM
Somehow, use of the word "banging" (even if "mild" or "moderate") sounds a lot worse than the typical gentle thud of piston slap. Could be oil that's too thick to circulate in extreme cold. But we still don't know what oil he is using, and whether it's particularly cold when this happens.
Injuneer is offline
Old 02-07-2015, 04:20 PM
kksi's Avatar
I agree that banging is too harsh a word. A piston slap seems correct and more appropriate. I dont change my own oil and regularly have it done at a service station. I hope and trust they use the recommended oil. The "slap" only happens on very cold days and again only lasts 10 20 seconds or so. Then it disappears. My intent on this thread was to see if this is an indicator of long term problems and if there is anything I can do to prevent any further damage. With 140k miles, should I consider a synthetic oil?
kksi is offline
Old 02-07-2015, 05:51 PM
Piston slap of the type you describe is very common on the LT1 (and the LS1 as well). Does not do any permanent damage. Make sure they are using 5W-30 in cold weather. Makes no matter whether its synthetic or not.
Injuneer is offline
Quick Reply: Engine banging at start up
