Electrical Nightmare HELP!
Old 04-24-2016, 07:36 PM
Justin Shubert's Avatar
Ok so tuesday night i went to start the car and I get no power to the gauges nothing.... I replaced the Ign Lock Cyl, and the Ignition Switch... Still no dice... I am at a complete lose... I have no idea where to look now and what to do.... Should I replace all my fusible links?
Justin Shubert is offline
Old 04-24-2016, 10:01 PM
Re: Electrical Nightmare HELP!
You need to add a "signature" with basic info about your car.... year, model, trans type and any major modifications. For example, there are sometimes subtle differences in the wiring year to year. In this case, there are different ignition switches for manual and auto trans. That way we can point you to the correct wiring diagram and tell you where to check for 12V supply at the switch.
Injuneer is offline
Old 04-24-2016, 10:05 PM
Fatdog2's Avatar
Battery? Battery cables---cable to the starter corroded?What year car?Might post your car in a sig. Do you live in a cold climate as the battery terminals could be the culprit.Hope this helps.
Fatdog2 is offline
Old 04-25-2016, 08:31 AM
it is a 1995 CZ28 w/ M6. 355 cc503 cam tuned by solomon, lt headers. I got a new switch and lock cylinder to no aval. I got a switch prt# LS309 from autozone is what they provided me with and still nothing... No power to gauges, now when I added this new switch my radio and turn signals no longer work when ignition is keyed on..... pls help
Old 04-25-2016, 11:25 AM
Check for 12 volts on the red wire to the ignition switch. That will tell you if the fusible link at the red "+" box is OK.
Here is Shoebox's info on the igntion switches for manual and auto trans. Check to see if you got the correct replacement. Also make sure you adjusted the connecting rod correctly.
4th Gen F-body Ignition Switch Replacement
And, from Shoebox, here is your wiring diagram:
http://shbox.com/1/ignswschematic.jpg
https://www.camaroz28.com/forums/lt1...nature-879835/
Injuneer is offline
kozmosis
11-02-2015 08:29 AM
Jcastro2333
07-27-2015 09:49 PM
gonzo275rltw
07-11-2015 04:19 AM
Dzmaro
06-19-2015 11:38 AM
gelbza
05-20-2015 12:48 PM
Quick Reply: Electrical Nightmare HELP!
