electric water pump????
Is anyone running an electric water pump? I will be down in that area anyways when I do my cam swap and everything so i was looking into a water pump. My car only has 40k so i really dont need one...i was jsut curious about the electric one. Does it help you any. Do they last...i have heard that these die quickly. also...what belt size would I need if I went to that set-up. Thanks.
Re: electric water pump????
Belt size doesn't change with an electric water pump on an LT1[it's driven off the cam thru the timing cover]
You get a Meziere or CSI pump for LT1, then bash out the impeller and bearing/seal in the stock housing, take the front plate off it, then bolt the electric pump to the housing..
Use a relay in the power source..
Originally Posted by skibbe_96z
so does this set-up free up some horsepower? or is it a lost cause and i should keep the original one on?
