Do air foils work?
Old 04-04-2003, 12:06 PM
ford's Avatar
Do air foils work?
Do they make any kind of noticeable difference or not?
ford is offline
Old 04-04-2003, 12:10 PM
Thebeast431's Avatar
In theory it should, but I don't think it will make a noticable improvement for $40. I didn't notice any difference with mine.
The dyno may say a 5hp and 5 lbs tq, but that is, more than likely, do to dyno error, or different weather conditions when each dyno was done.
Travis
Thebeast431 is offline
Old 04-04-2003, 12:40 PM
Bastardcat's Avatar
Yes, air foils work. No, you will not feel any noticeable difference.
Bastardcat is offline
Old 04-04-2003, 12:53 PM
n2ceptor's Avatar
I think www.ws6.com did a dyno on this...???
n2ceptor is offline
Old 04-04-2003, 01:04 PM
94F1Z28's Avatar
Yes they work.But you will not notice it,you may notice a little better throttle response.
94F1Z28 is offline
Old 04-04-2003, 01:14 PM
Gripenfelter's Avatar
My car whistles now with mine in there.
I took one from an L98 which has the airfoil going halfway into the intake elbow.
I ground down the edges and mated it upto the LT1.
My IAC counts changed at idle. That was about it. Mind you I'm not gonna notice a 4-6hp gain either.
Gripenfelter is offline
Old 04-04-2003, 01:15 PM
1997rblckSS's Avatar
does the SLP air foil fit on a 58 mm TB (edlebrock)??????
1997rblckSS is offline
Old 04-04-2003, 01:18 PM
94F1Z28's Avatar
The edlebrock 58mm already has one built in it.
94F1Z28 is offline
Old 04-04-2003, 01:25 PM
Are you sure?
Old 04-04-2003, 01:43 PM
chesee48's Avatar
I paid 15 shipped for mine, and i found out that i already had one in the car at the time hehe
So, i wouldnt pay much for one.
In my case, i didnt have to pay anything ata ll
chesee48 is offline
Bastardcat's Avatar
The 58mm Edelbrock Throttle Body does not have the air foil built in.
Old 04-04-2003, 01:54 PM
I didn't think so, I know the holley 58mm has one built in, that is why it cost way more...
so back to my original question, does the SLP air foil fit on the 58mm TB??
94z28jbw
09-08-2002 03:22 PM
Rich_z28
08-29-2002 10:44 PM
Rich_z28
08-27-2002 12:20 AM
BM93Z
08-22-2002 02:45 PM
turbo_Z
08-19-2002 10:50 PM
Quick Reply: Do air foils work?
