Differential gears
Differential gears
I started having an oil leak on the rear differential where the driveshaft connects. I've replaced the seal twice already in six months. And I'm still having a leak. I was told to change my diff bearings ...
Since I'm doing that, I thought of upgrading my gears... I'm thinking motive 4.10 gears with the motive master bearing kit...
Any thoughts on the gear choice
And the bearing choice...??
1995 Z28 Camaro M6, K&N A.I., CompCam Camshaft, Lifters, Pushrods, Rocker Arms and Springs. Pro 5.0 Short Shifter, No Cats, MadZ28 Tuned. BBK 58mm TB. De-screened MAF. HSpower LT headers,
Re: Differential gears
So I'm thinking about upgrading to 4.10 gears and new bearings to ...
4.10's are good with the 94 and up T56, with the steep O/D 5th and 6th gears.
When the gears are installed, you need an install kit, and a complete kit will include new side bearings and pinion bearings.
Has the housing pinion seal bearing area been inspected for damage? Should not get leaks with a newly installed seal.
MODERATOR NOTE: If you are posting from a phone, some apps will not append the signature.
I have a 94 with 4.10 gears and like it a lot, feels good on the freeway (not too much rpm) and at the track it is in a good rom crossing the line with 26" tires. 28" if running on the bottle works good too.
I have the 4.10s and I think it was a aburn posi built by hoopers rear end here in ca.
I'm building a ford 8.8 for my car now. I just need the axle tubes and brackets from this rear end. If you are interested in the gear set. Then would just need a instal kit, shims etc.
F'n1996Z28SS
08-23-2023 11:19 PM
carguyshu
01-22-2017 11:19 AM
