Difference between 93 and 94 ICM/Coil
Whats the difference between the two? They're two different part numbers, but they both fit the same and connect the same? Need insight here ASAP
Re: Difference between 93 and 94 ICM/Coil
Originally Posted by Fastbird93
I don't believe there's a change in the coil/icm setup until something like 95 or 96.
Factory coils and ICMs are split:
93
94-95
96-97
IMO, I don't think there would be any problem interchanging the 93 with 94-95.
I wouldnt think so. I DID notice that 93s are bolted and not studded towards the fender, and dont have two of the grounds the later coil/icm does, though I dont know if thats the reason for the PN change
NewsBot
09-30-2015 04:20 PM
