Crazy noise and then smoke :(
Old 11-17-2014, 02:50 PM
lovemyblackz28's Avatar
I started my car and I noticed the air bag light was on. Then I heard this loud noise that I havent heard before. I shut the car off right away (it was running for maybe 15 seconds). The car is off and this noise is still going on. A loud buzzing noise, sounded like it was coming from the back of the engine. Thought maybe it was the fans at first. After about 3 minutes, the noise still going, Smoke starts to come out on the left back side of the engine. Im thinking this isnt good. I decided then to disconnect the battery. Once i did that, the noise stopped immediately. What can it be?
lovemyblackz28 is offline
Old 11-17-2014, 05:05 PM
Re: Crazy noise and then smoke :(
The smoke was white. It was coming from the back of the engine towards the passenger side. Smelled like something electrical was burning. I haven't restarted it yet.
Old 11-17-2014, 06:10 PM
multicar's Avatar
That's the area where your starter is located. If I had to wager a SWAG; I'd say it may not start the next time. You might get lucky and it's only a shorted positive starter cable to ground, but that wouldn't explain the 'loud noise'. I'd trace the cable out first, then see what happens when you connect the battery back up for a few seconds.
multicar is offline
Old 11-26-2014, 04:15 PM
Just put in a new starter and all is well.
greenzee28
09-25-2015 04:29 PM
autoxr166
09-25-2015 04:21 PM
Ryan Ramsaran
09-19-2015 08:43 PM
jackpawt883
09-10-2015 08:53 PM
blaze309
09-08-2015 05:27 PM
Quick Reply: Crazy noise and then smoke :(
