Crank Replacement
Old 11-20-2014, 08:48 AM
1996LT1Z28's Avatar
Crank Replacement
I need to replace the crank in my 96 Z....don't ask, but it's slightly bent at the balancer.
I have a crank from another LT1, which is in great shape....bearings look great, all mic'd out well within spec.
Now....do I need to worry about rebalancing the rotating assembly?
Should I use the bearings out of the donor engine that are "matched" to the replacement crank, or just buy new bearings (I think I know the answer to that one). Just need an opinion...
Thanks!!
1996LT1Z28 is offline
Old 11-22-2014, 04:43 AM
green.Z's Avatar
Re: Crank Replacement
If you're re-using the same pistons and connecting rods, I'd say you're probably OK to skip balancing. Especially if you just want to repair the car.
I would definitely buy new main and rod bearings, sized to the replacement crank. I would also make sure to check the resulting bearing clearance with some Plastigage during assembly. That's cheap insurance.
You may want to consider getting the replacement crank Magnafluxed, just to make sure there are no cracks.
green.Z is offline
Old 11-22-2014, 11:10 AM
1996LT1Z28's Avatar
green.Z -
Yep, keeping the same rods and pistons. I'll take your suggestion and get std size bearings and check with plastigage.
Thanks for your time
Old 11-22-2014, 11:19 AM
I'd have the new crank checked, polished, then mic'd. Then, you can get bearings to fit.
shoebox is offline
Old 11-22-2014, 07:51 PM
1996LT1Z28's Avatar
Shoebox...will do. Thanks!
Old 11-29-2014, 08:55 PM
8cylinders>4's Avatar
Ridge Reamer? you've obviously never had a LT1 or any relatively current 350 SBC a part. The last ring ridge I saw was from a late 70's early 80's "lightweight" 305
Here's a pic of a 150,000 miles lt1 cylinder
8cylinders>4 is offline
Old 11-30-2014, 04:24 PM
MachinistOne's Avatar
Originally Posted by cardo0
I bought my ridge reamer to get the pistons out of my original LT1 out of my '94 with <135K mi. So what u are telling me is a total farce as the pistons were stuck without it. But hey thx for sharing your pix.
Must have been a unique situation - most modern engines come apart at 150K+ with barely a perceivable lip, I haven't seen a bore worn enough to even consider using a ridge reamer in over a decade. Ridge reamers were used to keep from potentially damaging the ring lands so that pistons could be knurled and reused, but nobody reuses pistons these days so it's a pointless and time wasting labor operation.
MachinistOne is offline
Old 12-01-2014, 01:01 AM
So the OP in post #3 says hes reusing the pistons. Now u think he should pound them out? Now your telling me i didnt have a ridge on my LT1??
Regardless the OP can see for himself once he takes the motor apart he can see for himself whether he needs to remove a ridge. Your saying he should neglect that fact and just pound them out is lousy advice - by any means. Why do u insist there is no ridge when i know from my own LT1 there is/was one??? And again if there isnt a ridge the owner has no need for a reamer and if thats what your saying all i can say is DUH!
Boy, I can just imagine the vein in your forehead throbbing while you typed out that grammatical disaster.
Let's go about this point by point.
First off, I quoted you specifically and said it must have been under special circumstances that you needed a ridge reamer (in your opinion). Like I said, of the hundreds and hundreds of late model engines that I have built, I have never come across one that has had an actual lip worn into the top of the cylinder.
Second, I never said anything specific about the OP not needing one...you put those words into my mouth. On that point though, if the OP ends up finding a ridge that necessitates a ridge reamer he absolutely should not be reusing the pistons anyways so it's a moot point, this is not the 70's where labor is cheaper than parts, that is the reason why pistons were saved, knurled and reused with a light hone on the cylinder. That process is simply not done anymore so ridge reamers have gone the way of the dodo.
Third, if your statement about your pistons being unremovable without a ridge reamer wasn't a complete exaggeration or fabrication, that had to of been the most abused and poorly running LT1 in history.
Remember to take your blood pressure medicine.
Edit: I thought your username was familiar...you're the guy who created a big fuss over line honing in another thread and was subsequently told that you and your limited and ancient knowledge should get packing.
https://www.camaroz28.com/forums/lt1...-868738/page2/
10-31-2016 11:09 AM
cyteone
02-07-2015 06:04 PM
Alex Barnes
01-24-2015 10:21 PM
Jessie4tin
01-07-2015 08:53 AM
Quick Reply: Crank Replacement
