Coolant leak issues
Old 11-08-2014, 09:43 PM
pologreen97z's Avatar
Coolant leak issues
Hey all-
So, I was losing coolant and losing power steering sporadically at low speeds which I attributed to leaking on the belt/slippage on the ps pulley. I traced the leak(so I thought) to the GM crimp connection on the short 90 degree hose from the water pump to the bleeder valve on the heater hose. I replaced that hose and when I went to fill it with coolant via the spill free funnel, I started to get a steady stream coming out of the bottom of the water pump.
Any ideas here? I really did not think my issue was at the water pump or I would have thought the leak would have been far more pronounced. However, the stream was almost as steady as I was putting coolant in the radiator.
Thoughts?
pologreen97z is offline
Old 11-08-2014, 10:18 PM
Re: Coolant leak issues
If coolant is coming out of the weep hole in the bottom of the pump even before it is under pressure, the shaft seal is toast and you need a new pump.
shoebox is offline
Old 11-08-2014, 10:25 PM
Unfortunately, that's what I figured. I cannot for the life of me figure out why it just started leaking from the weep hole AFTER I replaced the heater hose. Then again, I usually filled it from the overflow while this time I filled directly at the radiator and it was a steady stream.
Any ideas for protecting the opti during removal?
Also, I noticed on Rock Auto that there are 2 different AC Delco water pumps. One is $97 and the other is $220. What's the difference?
calaban
05-18-2020 06:43 PM
Magenta_Hearts
03-29-2017 08:54 PM
kallcium
V6 Tech
10-07-2015 03:39 PM
Magenta_Hearts
03-25-2015 10:24 AM
dansam
07-20-2002 01:10 PM
Quick Reply: Coolant leak issues
