Coolant air bleed valve question
Old 08-15-2011, 03:55 PM
David94TA's Avatar
There is a coolant air bleed valve on the neck of the radiator hose inlet on the intake and another in what appears to be a 5/8 inch heater hose. Is this second one absolutely necessary or can you successfully bleed the system using only the one on the large radiator hose inlet? I ask because I am having to replace the 5/8 inch hose.
David94TA is offline
Old 08-15-2011, 04:17 PM
my1994z28's Avatar
Re: Coolant air bleed valve question
There is one on the thermostat housing,and one on a coolant hose that goes to the w/p..Having both bleeders makes it easier to get the air out faster.
my1994z28 is offline
Old 08-15-2011, 05:52 PM
JGuy07's Avatar
So you're saying you just don't want to hassle with it by fitting the section with the bleed screw back on? My opinion would be to go ahead and keep it, wouldn't take much more time fitting then what it would be to take it off...
JGuy07 is offline
Old 08-15-2011, 07:34 PM
David94TA's Avatar
No, that is not what I am saying! The hose in question has a leak right at the junction of the rubber hose and the metal fitting containing the bleed valve. I have already checked on getting a new replacement and the local GM dealer said that this hose is showing as being discontinued but that he could possiblity get it for around $200.00. Now as far as dealing with the "hassle", I can replace a section of the hose and fab up a bleed valve--my question was simply will the one bleed valve in the thermostat housing be sufficient or is this second one absolutely necessary. Any time I have bled the coolant system, I have always gotten a lot more air out of the thermostat housing bleed valve than the other one.
Old 08-15-2011, 08:50 PM
ACE1252's Avatar
Read this....
https://www.camaroz28.com/forums/sho...d.php?t=819889
ACE1252 is offline
Old 08-15-2011, 10:13 PM
If the hose piece with the hole is #7 in this diagram (piece between bleeder and w/p), it is GM PART # 10215999 . You can carefully slit and peel off the swaged collar holding the hose to the bleeder assy and put the new little hose on with a normal hose clamp.
$200 would be for the complete heater hose assy, that is both hoses and metal pipe from w/p to heater core.
shoebox is offline
Old 08-16-2011, 06:59 AM
David94TA's Avatar
OK, thanks.
Old 08-16-2011, 11:47 AM
boostedz28lt1's Avatar
I have a heater hose complete for 50 shipped.
boostedz28lt1 is offline
Old 08-16-2011, 07:10 PM
David94TA's Avatar
PM sent
Old 08-16-2011, 11:21 PM
In reference to post #6, here is how you can replace individual hoses.
shoebox is offline
Old 11-17-2011, 07:24 PM
BigBlackBeaSSt's Avatar
There is an easier way to bleed the system and not run coolant down the front of the motor.
BigBlackBeaSSt is offline
Old 11-18-2011, 05:24 PM
Please handle parts for sale with a "PM", not in the tech forums.
Injuneer is offline
Old 11-20-2011, 10:21 AM
pgerst's Avatar
bigblackbeasst -- where did you get that bleed valve? That is always my least favorite part of the coolant process; messing up the newly cleaned engine. Much better than a rag which becomes one with the power steering pump pulley...not that that has happened to me twice.
pgerst is offline
Old 11-20-2011, 08:39 PM
I buy them in bulk and sell them. I have a running group purchase at this link.
http://www.impalassforum.com/vBullet...d.php?t=255705
Brass are not very popular, so I only order the nickel plated brass version now. Not accepting Paypals any more this year, as Obama is dipping his hand in that pocket as well. Money orders work.
Tim
oldschool
02-09-2016 09:21 PM
LT14LIFE
02-09-2015 09:35 PM
95chwagon
01-13-2015 09:19 PM
AlaskaZ28
12-10-2014 02:39 PM
AlaskaZ28
12-10-2014 02:37 PM
Quick Reply: Coolant air bleed valve question
