Cleaned out TB and IAC now engine light is on
Old 10-02-2004, 03:58 PM
NuMbNuTs670's Avatar
I cleaned out the TB 2 days ago and today I got a egine light and the codes are for IAC,TPS, high RPM idle its idling at 1,200 PRMs. When i was cleaning all the build up on the IAC i think i might have moved the spring a little. What could i have done to make it throw me these codes and what can I do to make the light go away?
NuMbNuTs670 is offline
Old 10-02-2004, 06:12 PM
Re: Cleaned out TB and IAC now engine light is on
ttt
Old 10-02-2004, 09:36 PM
Did you remember to plug both sensors back in? Connectors oriented properly and no bent pins?
How did you clean the IAC? Did you spray liquid solvent into the actuator (not recommended)? Did you attempt to move the pintle (not recommended)?
Injuneer is offline
Old 10-02-2004, 11:11 PM
Damn, used TB cleaner, how much is a new 1?
David Dorris
01-17-2015 08:10 PM
bfmv13trivium
01-14-2015 09:57 AM
dirtybird81
10
01-06-2015 09:31 PM
01-05-2015 07:14 PM
07-04-2005 05:00 PM
Quick Reply: Cleaned out TB and IAC now engine light is on
