castrol syntec question..
Old 07-28-2004, 01:41 PM
slverbullet's Avatar
i'm switching to castrol syntec in my car and just wanted to know if there is any real difference between the american version and the german one? i remember reading to pick up the german kind, however when i bought a case today that had slipped my mind until i got home. the one i bought is the american. dont figure its going to make that much difference, just wanted to know what the reasoning was for buying the german version. thanks
dave
slverbullet is offline
Old 07-28-2004, 01:51 PM
quicksilver97ta's Avatar
Re: castrol syntec question..
Your thinking of the Mobil1 0-30wt made in Germany.
FWIW, I do like the Castrol Syntec 5-50wt.
quicksilver97ta is offline
Old 07-28-2004, 02:20 PM
Spinner's Avatar
No, he's thinking of the Castrol Synthetic made in Germany, which is leaps and bounds better then the American formula. It's also neon green.
Spinner is offline
Old 07-28-2004, 03:14 PM
Spinner's right, it is the Castrol. Didn't know it was neon green (the bottle right?), should be easy to spot.
Old 07-28-2004, 03:49 PM
tomatocity's Avatar
dave
I recently started using Mobil 1 and because of information found at this group I will be purchasing it in the 5-quart container at Walmart, $20.02. The Castrol Synthetic sounds interesting. How do these brands compare with each other?
tomatocity is offline
Old 07-28-2004, 03:59 PM
Spinner's Avatar
No, the motor oil itself is neon green. Neat to look at, for sure.
Spinner is offline
Old 07-28-2004, 04:14 PM
Advanced Tech Moderator
kmook's Avatar
Really? I have 11 quarts of this at home for my build, but never opened any.
kmook is offline
Old 07-28-2004, 10:22 PM
Spinner's Avatar
Yep.
Spinner is offline
Old 07-28-2004, 10:28 PM
turbo_Z's Avatar
so you say most stores stock both versions and how do they compare in price?
turbo_Z is offline
Old 07-28-2004, 10:35 PM
kmook's Avatar
No, as far as I know and have found Autozone is the only one that carries the German made one.
kmook is offline
Old 07-28-2004, 10:57 PM
lovescamaros25's Avatar
at walmart mobil 1 runs about $4.77 a qt.ive heard mobil 1 is better than syntec.
lovescamaros25 is offline
Old 07-28-2004, 11:02 PM
YZF/LS1 Freak's Avatar
Mobil 1 15W-50 all the way
YZF/LS1 Freak is offline
Old 07-28-2004, 11:05 PM
stereomandan's Avatar
I'll stick with my 10W30 Mobil-1 based on results I've seen online. I'm sure the Castrol is good stuff too. (It's the German stuff that you want, based on Patman's work)
Dan
stereomandan is offline
Old 07-28-2004, 11:10 PM
Spinner's Avatar
We get mobil 1 for $3.50 a qt at work our cost wholesale. It's a killer deal.
Spinner is offline
Old 07-28-2004, 11:45 PM
eagleknight97's Avatar
Whats the weight of the Castrol oil? I would like to try it, but cant seem to find it anywhere.
eagleknight97 is offline
Quick Reply: castrol syntec question..
