Carburetor Motor In A 96 Camaro?????
Old 12-09-2004, 04:38 PM
TURBOnCAMARO's Avatar
IM INSTALLING A 350 CARB MOTOR IN MY 96 CAMARO. DOES ANYBODY KNOW ANYBODY THAT HAS DONE IT?? DO YOU HAVE PICS?? WHAT AM I GOING TO HAVE TO DO SPECIAL???
ANY HELP WILL BE APPRECIATED..
THANKS
NBUCK86SS@AOL.COM
TURBOnCAMARO is offline
Old 12-09-2004, 05:04 PM
Rockin94Z's Avatar
Re: Carburetor Motor In A 96 Camaro?????
if i may ask why not stick with the lt1?
Rockin94Z is offline
Old 12-09-2004, 05:12 PM
Birdman7389's Avatar
my thoughts exactly.......why do you want to put a carbed mortor in there?
Birdman7389 is offline
Old 12-09-2004, 05:15 PM
brendon444's Avatar
id would rather have one too easier to work on less expensive and not so much ****ing electrical ****
brendon444 is offline
Old 12-09-2004, 05:18 PM
944v8inDFW's Avatar
but wait the fun has not even started on the electrical, think it is a nightmare now wait till you have to figure out how to drive the guages, tach and fans with no connection because the PCM is no longer hooked to the engine
944v8inDFW is offline
Old 12-09-2004, 05:40 PM
it was a v6 motor thats why.. also im not going to drive it on the street..
anybody know anything about doing it???
Old 12-09-2004, 06:01 PM
WhtLT1's Avatar
Go to ls1tech.com and check out the carbed section they should be able to help, or do a search
WhtLT1 is offline
Old 12-09-2004, 06:18 PM
ejfagala's Avatar
Is it a stick or Auto?
You wil need to work the assy situation out but other then that just stick it in and hook it up. You may need to retain the ECM if the VSS runs through it but other then that the tem sensor, tach and oil presure all worl off sensors that can be transfered over. I personaly would never go back to a carb but its your car so good luck. If you have a 460E tranny then you are going to have problems. I believe it will require a box that cost about $500. I make over 400 RWHP and get 17MPG in town and would never go back.
ejfagala is offline
Steve69SS396
Track Kill Stories
15
08-10-2015 02:45 PM
01-05-2015 07:14 PM
Collector Car
01-05-2015 10:58 AM
NewsBot
12-28-2014 06:20 PM
ChrisFrez
12-07-2014 11:32 AM
Quick Reply: Carburetor Motor In A 96 Camaro?????
