Car stumbles then dies, need help!!
Re: Car stumbles then dies, need help!!
The fuel filter is easy. All you need is the right size wrench (I'm not sure what size, but it's a fairly common one). The only main issue is any rust- I would spray the area with WD-40 first just to make sure you don't twist too hard and bend lines. Other than that, you'll want something to plug the lines with so you don't have gas dripping on you.
Also, a fuel pressure tester/gauge available at Autozone/Advance Auto will help a lot.
check the fuel pressure. If its low then replace the fuel filter. If that doesn't help you need a pump. If the pressure is fine you must have an ignition problem.
