car still not right and gas mileage is LOW
this thing still aint running right. left o2 still reading lean. not sure what everything else is supposed to read. wont shift at WOT. and gas mileage is LOW. i filled it up till it was bout to run back out and i only went 98 miles before it was time to put more gas in it. i only have 3.42's and a 2800 vig. stall. i put a new o2 sensor in and it read the same as the one that i took out. i checked all connections and they were fine. it was running fine before the heads n cam swap. i get code 33 from time to time. i changed plugs n stuff. what else can i do about the sensor reading low. i read a previous post about the bosch sensors. could that be my problem. my other one(the one thats reading ok) is a gm o2
Re: car still not right and gas mileage is LOW
Most people will tell you that the Bosch O2s are junk. I wouldnt trust them on my car just for the simple fact that O2s are parts that should last well over a year and beyond, and Bosch's last about 3 minutes in some cases.
If that O2 is a bosch that is your problem, i currently just did my LT install and i now have the exact same problem as you after i used bosch 02's im waiting unpatiently for f*cking UPS to get here before 8pm tonight so i can fix this damn problem.
Pull that bosch asap.
Yeah, and damn UPS is still not here. 7:00pm i want these damn bosch 02's out of my damn car. I think im gonna smash the fawkers with a hammer.
i bought some dead soft aluminum gaskets and its still leaking. are they crappy? should i just get some copper collector gaskets? thats the kind of header gaskets i have
My tuner advised factory steel gaskets @ header to head connection. I just bouught a set of aluminum, but have not installed. If flange serfaces are flat and square, bolts tight, seems like they should work. Are you running factory injrctors? Did you reprogram PCm if not?
