car backfired a few times than died
ok, long story short, a buddy of mine was driving his Z down the freeway and it backfired a few times then died... we had it towed to my house and we tested the fuel preasure (sits steady at 41), replaced the coil pack, plugs, and wires, verified the valve train was ok, and it still wont run. You can turn the car over and it will start and idle at 200 rpm's as long as you keep your foot on the break. ignition timing was at about 12 degrees. I think it's the opti-spark... any other ideas of what it could be if it isn't this?
Re: car backfired a few times than died
Originally Posted by musclecar
I'm no genius with these things but I am guessing the opti as well. They seem to do some really oddball stuff on their way out. Good luck with it.
Originally Posted by S8ER95Z
Sounds like opti to me.. .honestly its not a very difficult part to change and if you got a good deal on it.. its worth swapping it now
Something similar happened to my 94. I was driving it when all of a sudden it back fired and cut off. I tried to fire it up and it would die right away. After a while it would just crank. When I checked there was spark at the coil but none out the opti. Most likely its the opti I would say..
It ended up bein the opti.... we replaced the opti and got new 8.5 wires (the wires were a complete PITA to route) and it fired right up. He said it runs better now than it ever did.
Kick ***!!!! Thats how mine was...I was so used to the way it ran..that when I went to give it gas to leave my ally I lit the tires up. I had a huge grin for a month after.
