A/C clutch diode
Old 08-22-2016, 05:53 PM
Ryan Sandell's Avatar
A/C clutch diode
I had to replace the electrical connector to the A/C clutch on my 94 Trans Am, but there was not a diode between the two wires anywhere near the connector. One diagram I saw said it should be 16mm from the connector. At the top of the engine where the harness joins up with the fuel injector harness, there is a long epoxy filled tube hooked to the black wire, but I can't see the other end to see if the green wire goes into it. Did the location of the diode change over the years? The new connector with 12" pigtail does not have a diode.
Ryan Sandell is offline
Old 08-22-2016, 10:55 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: A/C clutch diode
Here is the diagram from the 94 service manual. You can get the whole manual using a link here: http://www.mediafire.com/download/v2...n_complete.pdf
Click on the image to make it clearer.
Attached Thumbnails A/C clutch diode-ac-diode-location.jpg
GaryDoug is offline
plattted
West South Central
09-07-2015 02:45 PM
Anon
07-23-2015 12:18 PM
browenb
07-19-2015 04:14 PM
cboyer45
Parts Wanted
9
06-17-2015 10:51 AM
Chet1185
05-10-2015 09:24 AM
Quick Reply: A/C clutch diode
