Black smoke, won't stay running
Old 06-12-2015, 08:18 PM
z28cam1993's Avatar
Hi all. Very new to site but was given great info before now I have a slightly different problem.
I just replaced the fuel regulator back to stock. Also pulled all injectors sent out to be cleaned repaired and tested. And replaced plugs. Wires were msd new
Took alittle to crank over (been sitting 3 weeks), once it started you had to keep
Your foot on the gas at 2k rpms or would stall. A lot of black smoke when you hit gas than would taper off and very light cloudy smoke. Didn't smell nor was it wet. After I let off pedal
It immediately dies. Than I noticed a puddle of antifreeze on floor and sprayed in engine bay and plugs on opti were wet. Now I know I have a lot going on at once but any info at all would be awesome.
z28cam1993 is offline
Old 06-12-2015, 08:25 PM
Re: Black smoke, won't stay running
A problem with the coolant temp sensor could cause an excessively rich cold start on a warm day. See if the coolant problem is related to the temp sensor, or affected the temp sensor in the water pump housing.
Could also be a problem with the replacement fuel pressure regulator. Did you check the fuel pressure after the install?
Injuneer is online now
Old 06-12-2015, 08:31 PM
z28cam1993's Avatar
No I will continue tom and check the pressure now and see if better.
How do I test that temp sensor?
Old 06-12-2015, 08:53 PM
There's a temp sensor test procedure on shbox.com
I can't post the link because I'm on my phone.
There's a lot to be said for using Scan9495 (also on 93) to actually watch the sensor readings.
Old 06-12-2015, 10:19 PM
z28cam1993's Avatar
Ok. That site is so informative. Thank you.
So from briefly what I told you does it sound like the dreaded opti? I'm going to purchase a spark plug tester tom to check every wire.
Old 06-13-2015, 09:03 AM
I would look at what I mentioned before suspecting the Opti. That's why a data log makes sense.
Old 06-13-2015, 09:13 AM
z28cam1993's Avatar
Ok. I'm ordering the obd1 to USB cable to run scan program and see what happens. Thanks for your help
Old 06-23-2015, 06:25 PM
z28cam1993's Avatar
Ok. I flashed the car today and received troubled code 15. I think that's Coolant sensor circuit-low temperature indicated. Now what? Do I replace the sensor?
Old 06-23-2015, 06:41 PM
moparman's Avatar
Code 15 is the coolant temp sensor.
moparman is offline
Old 06-23-2015, 06:42 PM
z28cam1993's Avatar
Ok. So does the sensor just get replaced or do I need to do anything else
Old 06-23-2015, 07:05 PM
z28cam1993's Avatar
Is it in the water pump or side of block? I remember last week my waterpump was leaking coolant maybe this is why
Old 06-23-2015, 07:14 PM
timnfxr's Avatar
Water pump coolant temp sensor is the one monitored by the PCM. The driver's side coolant temp sensor is just for the temp gauge in the dash.
Have you tried resetting the PCM to clear the code? Does it return?
timnfxr is offline
Old 06-23-2015, 07:15 PM
z28cam1993's Avatar
How do i reset it? Car was idling and revving great finally. Went to go in reverse and died instantly.
Old 06-23-2015, 07:26 PM
Test the sensor and wiring using the procedure on shbox.com. Could be an open circuit in the wiring. Could be a faulty sensor. That's why I mentioned the sensor and the test procedure earlier.
Old 06-23-2015, 09:14 PM
z28cam1993's Avatar
Yes you did mention that. You seem to know a whole lot about these cars. That's awesome. I'll read up on testing it tom
DirtyDaveW
12-01-2016 05:37 PM
10-31-2016 11:09 AM
Jessie4tin
01-07-2015 08:53 AM
F(ast)-body
02-26-2003 09:05 AM
RedLineRev
01-23-2003 03:51 PM
Quick Reply: Black smoke, won't stay running
