pcv line
pcv line
Hey guys on my pcv hose the other end that inserts in the intake manifold the hose has a kink in it causing a annoying noise like squealing,i would like to kno what i can to make it
stop. my pcv rattles n there is vacuum too
Re: pcv line
i work at a dealership so its quite simple for me to check on whats discontinued and what's not
Re: pcv line
order a new hose from gm... i forget the part number but im sure shoebox or someone else will have it soon for you. i had to replace mine a month or 2 ago so i know gm still has them floating around in their parts room
Re: pcv line
First ? Why did u have to change your pcv hose/or what problems did it give u and the othet one.may i get the info from u on the rubber hose that that goes into the intake manifold if u kno if they have that part in stock still? And thank u n rob for the replies back it was fast
Re: pcv line
Hey guys thank u it turns out it was my pcv valve was clogged it had oil in it buy my oil isnt leaking anymore.but ill need to change the pcv valve i just cleaned it for now.and the pcv elbow hose is good.
