Bailey LTCC Imput
Old 01-26-2015, 09:13 AM
  #16
maybe2fast's Avatar
Re: Bailey LTCC Imput
I am going to use LS2 coils. I am starting a thread with my ideas for coil mock-up
maybe2fast is offline
Old 01-26-2015, 01:49 PM
  #17
Originally Posted by 87Aerocoupe
Thanks for the input guys I am building a new all forged 383 and I got a great deal on a new MSD opti so I too your advice and just loctited the rotor screws. I will cap off the coil and plug wire openings just to keep junk out. I'm also going to get the EFI Connections coil brackets, but which coils are you guys using? I've heard the LS2 or LS3 coils are the ones to use, any advice?
My setup (not powered by the LTCC) was installed in 2000, and the only thing available was the LS1 coils. They are more than adequate, firing a 300-shot of nitrous. Buddy of mine use the exact same setup on his Vortech blown 383ci 30th SS convertible, and was making 1,125HP at the flywheel, and turning high 7,000 RPM. Not sure what better endorsement you can get than that.
I also have a unique approach to mounting the coils. Would be a PITA to mount them on the valve covers, with a solid roller cam.
https://www.camaroz28.com/forums/mem...ils01-6225.jpg
https://www.camaroz28.com/forums/mem...oilsr-6227.jpg
https://www.camaroz28.com/forums/mem...04157-6223.jpg
This location is not all that great with a S/C..... a broken belt will wipe out the plug wires.
Injuneer is online now
Old 01-29-2015, 02:11 AM
  #18
97WS6SCharged's Avatar
I used the same stock LS1 coils on my 383 YSi setup and am transferring them to the new TT408 build.
I originally had the coils mounted on MBA fuel rail covers but adjusting valves sucks with them in the way. They are (were) currently mounted on the frame rails with the wires running down each rail.
97WS6SCharged is offline
Old 01-29-2015, 10:07 AM
  #19
Then there's the issue of trying to figure out where to hang 10 LS1 coils on a Viper V10, stuffed into a classic Barracuda.....
https://www.camaroz28.com/forums/mem...03690-6371.jpg
Old 02-01-2015, 11:36 AM
  #20
87Aerocoupe's Avatar
Thanks Injuneer and 97WS6Scharged you guys have answered all my questions, as I will also be adding a custom rear mount On3 78/76 turbo once I break the engine in and dyno it, so I wanted to make sure no spark blowout or high rpm miss. I know many people will say go EFI connections 24x which I have on my 94 Z28 but I don't want to repin the harness on my 97 SS (rare car) that's why I want the LTCC.
87Aerocoupe is offline
Old 02-05-2015, 05:18 AM
  #21
The coils will provide enough spark energy but you'll still need to adjust plug gap accordingly. At 800 rwhp I was around .026-.028 plug gaps. From what I've read some of the LSx guys have gone down to .022-.024 at the 1k mark.
Fred, do you recall what gaps Baxter was running?
Old 02-05-2015, 08:39 AM
  #22
Don't know his gaps. With the 300-shot of nitrous I run 0.028"
Old 03-15-2015, 11:45 AM
  #23
At the 750 - 800 rwhp mark on say 15# of intercooled boost and water meth what spark plugs would you guys recommend, and thanks again for all of your sage advice?
Injuneer
04-25-2022 06:22 PM
POLOVETTE 94
08-21-2015 07:11 PM
RobZ
08-01-2003 04:48 PM
robtx
06-06-2003 08:48 PM
DirtyDaveW
03-05-2003 02:45 PM
Quick Reply: Bailey LTCC Imput
