Anyway to control tire chirping/spinning between shifts?
Old 09-26-2004, 01:21 PM
Serene's Avatar
Is there any suspension parts that would minimize tirechirping during shifts? My car with the street twin, bmr lcas and brackets will chirp/spin every gear down the 1/4 mile.
Would any parts help me minimize this loss of ET? Torque arm with adj pinion angle?
Serene is offline
Old 09-26-2004, 02:07 PM
BiGGinZ's Avatar
Re: Anyway to control tire chirping/spinning between shifts?
Better tires.
BiGGinZ is offline
Old 09-26-2004, 02:17 PM
96ta(nick)'s Avatar
Originally Posted by BiGGinZ
Better tires.
That is the best thing you can do, But if you have a stock rear good luck with that...
96ta(nick) is offline
Old 09-26-2004, 02:18 PM
Serene's Avatar
it does it on ET streets.
Serene is offline
Old 09-26-2004, 02:19 PM
96ta(nick)'s Avatar
Torque arm might help then...
indieaz's Avatar
reduce tire pressure...try like 20 pounds. although i wouldn't recommend regular driving like that...but if you mean when you're at the track it'll work. I actually drove around a few days with 22 pounds in my tires...chirping solved. Now that they are inflated to 32 pounds tire spinning anywhere abover 2500rpm has resumed which isn't an entirely bad thing
indieaz is offline
Old 09-26-2004, 02:21 PM
BiGGinZ's Avatar
Then you aren't just spinning you are getting wheel hop. Just do the susp. things. I don't know what you have done already but do
LCA's
Torque Arm
Subframes
Springs
Shocks
And you should be ok.
BiGGinZ is offline
Serene's Avatar
this is on et streets with 14 psi or so in them. how do you guys do your burnouts? I set the line lock and start it out in 2nd gear and give a few secs of smoke and then roll out
Serene is offline
F'n1996Z28SS
08-23-2023 11:19 PM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
Quick Reply: Anyway to control tire chirping/spinning between shifts?
