Anyone using PROBE pistons?
#16
That is a good price for the budget forged piston. I thought you were looking at the sportsman race series (SRS) Probe piston which is more money.
If it's a goal to do this with the least money then this forged piston and moly ring kit is even cheaper than your Probe choice with rings.
Karl
Karl
Bore (in): 4.030 in.
Bore (mm): 102.362mm
Piston Material: Forged aluminum
Piston Style: Dish
Compression Distance (in): 1.560 in.
Valve Reliefs: D shaped cup
Piston Head Volume (cc): +21.10cc
above the piston head volume is a + i thought a blower dish piston had to have a - cc , i just maybe confused.
Im using the 58cc combustion chamber heads. where would these pistons put my CR.
#17
Mailorder tuners will set then up rich on the fuel and concervative on the spark so I see no real risk there just potential left untapped. Particularly with a turbo I would look to tune at the track the dyno is not the same load.
#18
Summit probably has that + in error.
Also, I don't want to advocate those Speed Pro pistons. I think they are teh most brittle forged pistons on earth. That's why they are so cheap.
karl
karl
#19
untapped potentional is what i like.
messes with peoples heads at the track.
Later as money is more avliable i will try a stand alone.
unless any one has a better idea for <$500
this thread is going to get moved.
#20
Re: Anyone using PROBE pistons?
i have probe 12cc dish top pistons and hellfire rings and have sprayed the hell out of it over 100 times with a 250 shot with no signs of failure, i have never heard of anyone with the proper tune cracking these pistons.
#21
There really isn't much point in replying to posts that are 7-8 years old. We're happy to see your comments but if the post isn't pretty new people have likely moved on...
#22
you are right the original user that posted this has probably vanished off the face of the earth, but when I'm researching car things there are many threads that i feel are incomplete, and i voiced my experience with what the thread was about not just about what i have read. When I'm researching things about engines i don't care if it's 7 or 20 years old i like to hear what people have to say about certain engine parts. I noticed that you are in Kissimmee not to far from me, would you like to race?
gonzo275rltw
09-05-2015 06:26 PM
gonzo275rltw
09-05-2015 06:24 PM
