Anyone using PROBE pistons?
http://www.probeindustries.com/
im on a really tight TwinTurbo Budget build. And these pistons are almost half the price of the brand names. I just havent heard of them before.
Anyone tried them yet?http://www.flatlanderracing.com/
yeah ive heard that alot, but im out to prove it can be done with engine mods for under 2k.
2 turbos
intercooler
fuel pump
fmu
injectors
8.9 comp.
3 bar map
etc.......
and all the stock stuff im going to be selling. it will be subtracted from the total cost.
I bough the car with a blown head gasket so i had to pull the motor anyway.
2 turbos
intercooler
fuel pump
fmu
injectors
8.9 comp.
3 bar map
etc.......
You'll need to buy piston rings in addition to the Probe pistons. A good set of rings is around $100 bucks or more.
I don't see the Probes being a lot cheaper than other brands like SRP or KB
Which Probe piston in particular are you looking at that will work will with your turbo combo?
Another budget piston to look at, (but not an all out tubo piston) would be the Mahle powerpak piston/ring sets.
SBC425030I26 $559 for example, or ---
SBC125030I16 $559 at flatlander racing.
Karl
Karl
I am not saying Probe is bad, I really know nothing about them.
I just want to point you back at quickSS post about you need to consider the whole package. Buying individual items because they initially apprear cheaper than the kit is a very common way to endup spending more than you intended.
Chevy 350-5.7 Rod - Dish Top
Ring Grooves: 5/64, 5/64, 3/16
Dish Volume: 20.3cc
Stroke Rod C/H Bore Weight Comp Ratio computed
w/.010 deck & .038 head gasket Part # Price/Set
58.0cc 64.0cc 68.0cc 76.0cc
3.480 5.700 1.560 4.000 486 8.75 8.26 7.97 7.46 P2441F-STD $329
4.030 498 8.86 8.37 8.07 7.55 P2441F-030 $329
4.040 504 8.89 8.40 8.10 7.58 P2441F-040 $329
4.060 513 8.96 8.47 8.17 7.64 P2441F-060 $329
rings extra but still not a bad price. i will have to bore my block .030 so that would put my comp at 8.86
Dish Volume: 20.3cc
I just bought my second matching turbo today off ebay $69 ship included, i wont tell you guys which kind, untill i see how they work.
Just to keep the HAHAHAHAHHAH posts from coming. its not china crap though.
Im sure that its just going to be an expensive experiment. but i lost my DL and have time to kill. (street racing is not cool anymore)
That is a good price for the budget forged piston. I thought you were looking at the sportsman race series (SRS) Probe piston which is more money.
If it's a goal to do this with the least money then this forged piston and moly ring kit is even cheaper than your Probe choice with rings.
Karl
Karl
but he will just give me a dyno sheet. For Free. Im a cheap ba$tard. if you couldnt tell already.
oh lots of fun so far. i listened to my old man who told me we should pull the motor from the top.(motor has never been out.) those freakin trans bolt were on soooooo tight. I almost broke both wrists getting them loose. and it took a few days.
For others who read this please drop the K member.
Im pretty confident that it will work. Ive done about 1yr of research on turbo systems.
Mail order tune.....anythoughts
I have gotten wonderful feed back about PCM4less
