Accessory bracket bolts?
Old 04-29-2011, 03:56 PM
LT1 POWR's Avatar
How important is the upper right bolt that threads into the head? I just put the accessory bracket up to my motor with brodix heads, and that threaded hole is missing? I have the 2 lower in the block and the other one in the head. I'm running the ac delete pulley if that matters, so a little less weight/stress on the bracket. At first I thought I had the passenger and drivers side heads on backwards, but the rear of the drivers head looks to be the same. I guess if I really need it, I could drill/tap the head for that bolt, but I really don't fell comfortable doing that. This build is just one complication after another.
Here is a picture courtesy of Shoebox.
LT1 POWR is offline
Old 04-29-2011, 05:23 PM
Re: Accessory bracket bolts?
I'd say you would be missing 1/4 of the holding power for the bracket. Not ideal, IMHO.
shoebox is offline
Old 04-29-2011, 09:38 PM
MeenZ28's Avatar
I have a modified stock acc bracket that relocates the alternator down low. The guy I bought from removed that top right "horn" for the stock alternator mounting along with the hole in question - haven't had an issue yet. But the weight of the alternator isn't up top anymore either so I don't know if that would make a difference.
MeenZ28 is offline
Old 04-30-2011, 11:29 AM
Bersaglieri's Avatar
Just for informational purposes the bolts that thread into the bracket for the AC are M10 1.50 and I'm pretty the bolts into the head/block are too. I saw the PS bolt size was listed, figured it'd be good to know.
-Dustin-
Bersaglieri is offline
Old 04-30-2011, 12:49 PM
-Dustin-
The bolts into the heads and block are 3/8-16. Virtually nothing going into the heads or block are metric.
shoebox is offline
Old 04-30-2011, 10:15 PM
Ah, then just the A/C mounting ones are M10 then. Not sure if you already have the info, but I have a bolt gauge and all the bolts to my motor lying around, just a thought.
-Dustin-
Old 04-30-2011, 11:21 PM
LT1 POWR's Avatar
I ended up welding a tab to the accessory bracket that lines up with one of the existing threaded holes in the head and all it solid now. Here are some pics for any future reference.
LT1 POWR is offline
Old 05-01-2011, 08:47 AM
Good deal.
shoebox is offline
Old 05-01-2011, 10:49 AM
LT1 POWR's Avatar
That tab may not look very structural, but it is just as strong as the cast accessory bracket.
LT1 POWR is offline
Victor Lamb
08-26-2017 02:52 PM
HectorM52
07-30-2017 11:46 AM
maybe2fast
03-16-2015 09:45 AM
Red97LT1
03-01-2015 05:08 PM
Noer
02-28-2015 11:29 AM
Quick Reply: Accessory bracket bolts?
