97 Z28 New GM water pump: Coolant leaking thru bolt holes. What to do?? - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 12-09-2010, 05:58 PM   #1
I'm about to pull my hair out on this one guys. I've tried everything. Brass washer under the head, used plenty of thread sealer on the threads, because I know they thread into the water jacket. I had a problem with my old water pump yesterday doing it on one side, now with the new GM pump it's one bolt on the other side. It's not a small leak either, and the bolts are all tight, and have been torqued in sequence to 30 lb-ft. I've used the search function and haven't turned up much. Any suggestions that have worked for any of you guys?
97Z28Muscle is offline   Reply With Quote
Old 12-09-2010, 06:11 PM   #2
Re: 97 Z28 New GM water pump: Coolant leaking thru bolt holes. What to do??
RTV is all i can say. I dont know of anybody that has had your trouble before. Take each bolt out only one at a time and put a generous amount of RTV on the threads and reinstall. Go to the next bolt and do the same. No need to take the wp back off. Make sure you have the opti covered before you start or you know what will happen.
bowtiedad_z28 is offline   Reply With Quote
Old 12-09-2010, 07:59 PM   #3
I found part of the problem. One of the bolts is deteriorated to the point where water/coolant is JUST able to pass by the threads. If you run your fingers along the threads, the bolt is actually larger on the end than 3/4" from the end of the bolt. I bought four new bolts at the hardware store and just got done installing them. That problem is gone, now I got another one. The heater hose on the front of the pump is now leaking all over the place. I tell you what, one problem after another on this water pump deal. Originally this all started due to an oil leak on the front cover(pinpointed that to the water pump drive shaft seal). That problem is solved now. The PCV valve hose was kinked and building enough pressure in the crank case(no vent) to force it out the front seal. Then I noticed the water pump leaking(older one), so I decided to replace it. Got the genuine GM part so it will last. Then the bolt hole water leak problem. Now a heater hose problem...this car has got me by the ***** right now.
Old 12-09-2010, 08:18 PM   #4
Jlo
Jlo's Avatar
Quote:
Welcome to the LT1 world..
Jlo is offline   Reply With Quote
Old 12-09-2010, 09:53 PM   #5
ACE1252's Avatar
Most of the time, it pays to get new hardware when swapping things out. When doing my water pump, I had new bolts from GM ready. Also chase the holes with a thread chaser. Permatex high temp thread sealant is what I used on the threads. Zero leaks.
ACE1252 is offline   Reply With Quote
Old 12-10-2010, 07:20 AM   #6
Quote:
X2...not silicone(RTV). This is the right stuff according to GM.
bw_hunter is offline   Reply With Quote
Old 12-10-2010, 08:22 AM   #7
I use permatex thread sealant with teflon..no problems,use on the intake bolts,water pump bolts.zero leaks.
my1994z28 is offline   Reply With Quote
Old 12-10-2010, 08:54 AM   #8
Yup, I used a teflon based thread sealant and four new bolts. I replaced the long bolts only, the other two are shorter and I don't know whether or not they enter the water jacket. That's a horrible design to have these bolts enter the water jacket, that's basically asking for the thing to leak...Anyways, i'll give an update later this evening after I get it all figured out today. Thanks for all the replies.
Old 12-10-2010, 04:28 PM   #9
It's a horrible design that lasted over 42 years...ever since the original small block, LOL
Old 12-10-2010, 11:38 PM   #10
Pretty much, bwhunter...LOL. I got it figured out today and actually took the damn thing for a drive. After replacing the worn bolts this thing hasn't leaked a drop. I'm learning more and more about my LT1 every day. I got the oil leak figured out too, it was a problem with the PCV valve. Got everything straightened out now and she really purrs. I can't wait to get some louder exhaust on this thing so I can actually hear the cam loping...Sweet thunders for me after I get a little more cash.
Old 12-11-2010, 07:48 PM   #11
ACE1252's Avatar
I learn something new about my car every time I work on it(I learn new cuss words too). I've went from just a couple of bolt ons to having taken the engine all the way down to the bare block in my time here over the last 13 years. The 4th gen Camaro is a good balance between speed and price. That is why I have kept mine for so long. I hope you enjoy yours too.
Reply
Thread Thread Starter Forum Replies Last Post
Coolant Disappearing? calaban LT1 Based Engine Tech 15 09-04-2016 04:11 PM
LT1 24x Conversion Parts Queens94z28 Parts For Sale 3 12-20-2014 10:11 PM
Heater Hose replacement pologreen97z LT1 Based Engine Tech 0 12-02-2014 11:42 AM
hey hey hey thenewkid New Member Introduction 5 11-27-2014 10:41 AM
slight overheating cristian1311 General 1967-2002 F-Body Tech 4 11-23-2014 03:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
