96Engine, Wiring, ECU in a 95 chassis plug and play?
Old 06-04-2014, 08:19 AM
browenb's Avatar
Wondering if the connections through the firewall are the same? I know OBDI/OBDII is different, got the covered, just wondering if the chassis are wired up the same.
browenb is offline
Old 06-04-2014, 12:57 PM
Re: 96Engine, Wiring, ECU in a 95 chassis plug and play?
Shoebox has a guide to the chassis connector pinouts, by year. There are differences 95 to 96. Note that there is a tab at the bottom of the page for each connector.
http://shbox.com/1/harness_connector_faces.htm
Injuneer is offline
Magenta_Hearts
03-29-2017 08:54 PM
PROJECT X
04-17-2015 12:13 AM
Magenta_Hearts
03-25-2015 10:24 AM
IgorT.455/406
03-12-2015 03:39 AM
rwferguson43026
02-06-2015 10:06 AM
Quick Reply: 96Engine, Wiring, ECU in a 95 chassis plug and play?
