96 z28 no start
Old 05-24-2016, 02:03 PM
  #61
black96camar's Avatar
Re: 96 z28 no start
Just checking everything right now
black96camar is offline
Old 05-24-2016, 02:11 PM
  #62
Re: 96 z28 no start
You really need to focus on one problem at a time, rather than jumping all over the place. You also need to respond to questions from the people trying to help you.
Injuneer is offline
Old 05-24-2016, 02:46 PM
  #63
Re: 96 z28 no start
I did I'm trying to look for vaccum leaks, trying to check the hoses that plug into the intake. And I taped up the elbow and got it on all the way, cleaned the maf, and I was lookin at the throttle body and all the hoses on the right side were ripped
Old 05-24-2016, 04:44 PM
  #64
Fatdog2's Avatar
Re: 96 z28 no start
Might take a look here-Vacuum leaks and LT1-----------Firebird Technical forum------fbtf.proboard.com/thread/11
Here they list a million places to check for vacuum leaks.Hope this helps.
Also there is quick fix for the LT1 evap purge line using an old spark plug boot on u-tube.(LT1 evap purge line repair).My02.
Fatdog2 is offline
Old 05-25-2016, 12:12 AM
  #65
Re: 96 z28 no start
Old 05-25-2016, 12:12 PM
  #66
94Z28LS1toLT1's Avatar
Re: 96 z28 no start
Originally Posted by Injuneer
There is no EGR "pump". Why are you asking about the EGR system?
Lmao has this thread been solved yet,or has his camaro even started yet? Long thread n now he's talking about a egr pump?
94Z28LS1toLT1 is offline
Old 05-25-2016, 12:47 PM
  #67
Re: 96 z28 no start
Car starts but won't idle unless given gas.
Old 05-25-2016, 07:02 PM
  #68
Re: 96 z28 no start
Got it to start and idle without giving it gas. But still won't Rev past 3000
Old 05-26-2016, 10:39 AM
  #69
Re: 96 z28 no start
So is it cutting off at 3000 rpm,n it won't stay on?
Old 05-26-2016, 01:52 PM
  #70
Re: 96 z28 no start
It will stay running I drive it around the block but couldn't get it to Rev past 3000 rpm and has hesitation when I hit the gas
Old 05-26-2016, 02:17 PM
  #71
timnfxr's Avatar
Re: 96 z28 no start
Have you checked the fuel pressure at idle and at 3000 RPM?
timnfxr is offline
Old 05-26-2016, 09:45 PM
  #72
Re: 96 z28 no start
Definitely couldn't agree more on that,I'd definitely check the fuel pressure at idle n 3000 rpm
Old 05-27-2016, 11:22 AM
  #73
Re: 96 z28 no start
I know it got bad gas, that I need to get out or drive till its close to empty, and plan on checking some things on payday
Old 05-30-2016, 08:21 PM
  #74
Re: 96 z28 no start
So I got no oil pressure. I checked it with a mechanical gauge, got 0 psi. Changed filter still got 0psi.
Old 05-30-2016, 10:58 PM
  #75
Re: 96 z28 no start
What happened with the bad gas,now it's oil pressure? Oil pressure can be a number of things I.e. oil pump,oil pump drive gear,oil pick up. Now what happened bcuz I thought u were having problems with it to stay on
Quick Reply: 96 z28 no start
