96 z28 no start
#17
Re: 96 z28 no start
The oil pickup is dead center, directly under the centerline of the crankshaft. The spec for the clearance is 5/16" to 3/8" between the low point of the pickup and the bottom of the pan.
#25
Re: 96 z28 no start
Does this mean you were able to start it after replacing the starter? Does it start at the turn of the key? Does it idle smoothly and at a steady speed?
You're driving along (part throttle, full throttle??) and the tach reaches 3,000 RPM. EXACTLY what happens? Engine starts to misfire and stumble? Engine just shuts down?
When you tested the fuel pressure did you test it under load, out on the highway? Or just at idle?
#26
Re: 96 z28 no start
Starts every I'm after replacing the starter. It doesn't idle smooth at all, but it was better then when It first started. Full and part throttle it jus doesn't have any pick up. And it jus starts to die out, and won't go over 15 mph. I only tested it at idle.
