96 z28 no start
#62
Re: 96 z28 no start
You really need to focus on one problem at a time, rather than jumping all over the place. You also need to respond to questions from the people trying to help you.
#63
Re: 96 z28 no start
I did I'm trying to look for vaccum leaks, trying to check the hoses that plug into the intake. And I taped up the elbow and got it on all the way, cleaned the maf, and I was lookin at the throttle body and all the hoses on the right side were ripped
#64
Re: 96 z28 no start
Might take a look here-Vacuum leaks and LT1-----------Firebird Technical forum------fbtf.proboard.com/thread/11
Here they list a million places to check for vacuum leaks.Hope this helps.
Also there is quick fix for the LT1 evap purge line using an old spark plug boot on u-tube.(LT1 evap purge line repair).My02.
#66
#72
#75
Re: 96 z28 no start
What happened with the bad gas,now it's oil pressure? Oil pressure can be a number of things I.e. oil pump,oil pump drive gear,oil pick up. Now what happened bcuz I thought u were having problems with it to stay on
