Low coolent sensor
Old 02-07-2017, 05:14 PM
zootzee's Avatar
Low coolent sensor
Hi guys.
I am getting a low coolent light on my dash. After looking around I found this is common and most people just pull the wire on the sensor that goes into the radiator.
I want ant to replace mine. Does anyone know the proper part number and where to order one from?
Thank you!!
zootzee is offline
Old 02-07-2017, 08:57 PM
gaedbo's Avatar
Re: Low coolent sensor
The old number is 10096163. The new number is 19299321. You may want to check your current Sensor connector to see if it is a 2 prong or 8 prong style. You can search for either # and get the correct results.
The 2 way fits 94 - 97 Z28's The 8 way fits 94 - 95 Z28's
I have a 95 Z28 and mine was the 2 way. The prices are all over the place from $5 to $95. I purchased mine a year and a half ago from Amazon for $18.50 and it has worked correct since the install.
You also may want to check out shbox.com for a great information website on your Z28
gaedbo is offline
Old 02-07-2017, 09:05 PM
zootzee's Avatar
Thanks for the info.
Mine is a 97 Trans Am. I'll check those part numbers and see what my Part stores have.
Appreciate the information.
zootzee is offline
Old 02-07-2017, 09:28 PM
gaedbo's Avatar
Here is a photo for reference, it is held in place with a wire like clip.
gaedbo is offline
Old 02-07-2017, 10:04 PM
zootzee's Avatar
Thanks again. And that site seems pretty awesome too!!
zootzee is offline
Old 02-07-2017, 11:23 PM
Fatdog2's Avatar
I just pulled one from a wrecking yard for a back up and it was corroded all inside as well as the metal sensor in it.I cleaned it up with a degreaser and Q tips till it looked clean.Haven't tested it yet though.Also take a look at #10195576 gm coolant level module.Autoparts warehouse feature the Standard#FLS-24 or s1fl24.They sure look the same to me.Hope this helps.
Fatdog2 is offline
Old 02-08-2017, 06:58 AM
zootzee's Avatar
"><img src=" /> ">
zootzee is offline
Old 02-08-2017, 07:00 AM
zootzee's Avatar
https://www.amazon.com/Genuine-19299321-Engine-Coolant-Indicator/dp/B00GV8UTYW
so this is what it looks like??
Thanks again guys!!
zootzee is offline
Old 02-08-2017, 04:09 PM
Correct part #.
But.... that part # was used in numerous GM vehicles. As a result, there are a number of lower priced aftermarket parts available, including very cheap Chinese rip-offs of unknown quality.
Example:
Firebird Coolant Level Auto Parts For Sale | Auto Parts for Cars, Trucks and SUVs
Injuneer is online now
Old 02-08-2017, 05:18 PM
gaedbo's Avatar
I was pretty lucky, the one I purchased from Amazon for the $18.50 was an actual GM Sensor. Came sealed up in the original GM plastic bag even. Yeah for me.
gaedbo is offline
Old 02-08-2017, 07:13 PM
zootzee's Avatar
that's a great price
zootzee is offline
Old 02-09-2017, 03:48 PM
zootzee's Avatar
$92 plus tax here in Canada.
zootzee is offline
Old 04-08-2017, 11:27 PM
zootzee's Avatar
OK guys, looooong story, but I finally installed the sensor.
BUT THE LIGHT IS STILL ON???????
Do I need to clear codes?
Thank you.
zootzee is offline
Old 04-09-2017, 07:11 AM
bw_hunter's Avatar
Thank you.
Check out the sensor wiring, the coolant level sensor doesn't set a code, it's independent of the PCM. So is the oil level sensor...
bw_hunter is offline
Old 04-09-2017, 09:38 AM
In 97 the circuit for the coolant level sensor goes through the body control module, which contains the latching relay. There are codes in the BCM (separate from the PCM) and I think there is a way to read them. Not sure if there is a code for the coolant level sensor. If I get a chance, I'll check the 96 factory manual. Or, you could download a copy of the manual and see what it says. 96 and 97 should be the same with regard to the BCM.
If you unplug the harness connector from the sensor, does the dash light go out? If not, could be a short between the two wire in the harness, or a fault in the BCM.
Free shop manual download:
https://www.mediafire.com/?40mfgeoe4ctti
