96 LT1 Won't Turn Over, Gauges Don't Turn On, ECM Not Getting Power
Old 10-18-2014, 04:30 PM
Alex Barnes's Avatar
Ok so, here's the deal, I was having issues with hard starting so, I hooked up a fuel pressure gauge to the valve behind the plenum, went to turn the key to "run" and got nothing. My radio and lights work, my ScanGauge II turns on (but won't connect to the computer) but the gauges don't perk up, the pump doesn't prime and the starter won't turn over. The battery has 12 volts of charge, the battery terminals are good, the ECM fuse in the fuse block under the hood isn't getting power, and my VATS is bypassed.
Alex Barnes is offline
Old 10-18-2014, 05:14 PM
4th Gen 4 Life's Avatar
Re: 96 LT1 Won't Turn Over, Gauges Don't Turn On, ECM Not Getting Power
Seems me and you both are experiencing issues from the computer. I think the best way for us to understand this is understand the different communications in a tuner and how the computer operates all together. I am in the same boat chasing down the issue. Anybody got a good guide to understanding the PCM and its controls.
94 Z28 A4- ported heads/intake long tube headers. Egr/smog delete.
4th Gen 4 Life is offline
Old 10-18-2014, 05:18 PM
I'll post from what I know. Maybe check the wiring to the fuel pump to make sure your getting power to it. This is similar of the problems Im having but the outcome of the problem could be from multiple sources.
Old 10-18-2014, 06:12 PM
Might need to check the ignition switch. See if you are getting power to fuses that are energized when the switch is turned to ON.
shoebox is offline
Old 10-18-2014, 07:24 PM
I wouldn't jump to the conclusion that it's a PCM problem. The dash gauges (fuel, oil, coolant, volts) don't interface with the PCM.
Injuneer is offline
Old 10-18-2014, 08:57 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Originally Posted by Alex Barnes
... the ECM fuse in the fuse block under the hood isn't getting power...
I don't see such a fuse in either the 96 owner's manual or the 96 service manual. Did you mean the fuse block inside the car?
GaryDoug is offline
Old 10-19-2014, 08:37 AM
Sorry I meant the ENG CNT fuse (or something along the lines IIRC).
Old 10-19-2014, 08:50 AM
Prominent Member
GaryDoug's Avatar
As shbox suggested, the ignition switch may be defective. Check the voltage at these fuses with the ignition switch on: Injector, engine sensor, ignition, ac/cruise which are all in the underhood box. Also air bag, pcm ign, gages which are all in the I/P (inside) panel. If all have no power, the problem is most likely a defective ignition switch. To further confirm that, check the voltage at the HVAC fuse inside, It should have power if the ignition switch is the fault. If not, the problem is upstream.
GaryDoug is offline
Old 10-22-2014, 05:05 PM
Thanks guys! It turned out to be my switch. The new one I installed is surprisingly stiff and has this thing called feedback that I had never experienced in my car before lol
brentbrowning01
12-16-2014 06:35 AM
A's 91 Z28
12-07-2014 12:09 PM
CaRParts102
12-06-2014 08:45 AM
ro2207
12-04-2014 06:18 PM
Red97LT1
08-07-2002 05:45 PM
Quick Reply: 96 LT1 Won't Turn Over, Gauges Don't Turn On, ECM Not Getting Power
