help water pump?
Old 06-11-2009, 04:35 PM
sick9lt1's Avatar
help water pump?
whats up guys need help with this, i was in my car for like 30 mins. i came home and parked the car, did not turn it off and open the hood it throwing water all over the place so i looked under the car and water was running down the front of the block behind the crank pully. so i turned the car off and it stoped. not even a min turned it back on and let it run for 15 mins and no water any where. then i reved up the motor alot and no leak what the hell is going on. thanks guys
sick9lt1 is offline
Old 06-11-2009, 05:05 PM
Stl94LT1's Avatar
Sounds like your water pump's bearing is shot.
Stl94LT1 is offline
Old 06-11-2009, 05:08 PM
sick9lt1's Avatar
Originally Posted by stl94lt1
sounds like your water pump's bearing is shot.
why dose it not do it all the time.
sick9lt1 is offline
Old 06-11-2009, 05:15 PM
Stl94LT1's Avatar
Depends on the position of the bearing. Our 95 TA did the same thing. Once the pump was off it was apparent.
Stl94LT1 is offline
Old 06-11-2009, 05:32 PM
sick9lt1's Avatar
so how do i find out if thats what it is or not. and what do i need to replace it. also i have a water pump off my othe motor how do i tell if this is still good i can see the bearing is good or not.
sick9lt1 is offline
Old 06-11-2009, 06:13 PM
Stl94LT1's Avatar
Get under the car and check the pump's weep hole. If it has signes of leakage, replace the pump.
Stl94LT1 is offline
Old 06-11-2009, 06:26 PM
sick9lt1's Avatar
lol i dod that and it did bot there was not a thing out there
sick9lt1 is offline
Old 06-11-2009, 08:35 PM
Stl94LT1's Avatar
Stl94LT1 is offline
Old 06-11-2009, 08:45 PM
lt1srule's Avatar
Theres your sign !!!
lt1srule is offline
Old 06-12-2009, 02:56 PM
sick9lt1's Avatar
well i have a pump and opti that i am going to put on. is there any way to tell if the opti is good with out it being on the car. and to change the pump do i need to drain the water out of everywhere?
sick9lt1 is offline
Old 06-13-2009, 11:46 AM
sick9lt1's Avatar
so you would think this pump is still good or can it still leak.
sick9lt1 is offline
Old 06-13-2009, 01:29 PM
I'd find out exactly where the water was coming from before starting to change out parts. If you lost enough water/coolant with the leak, there's a good possibility its not leaking any more because there's no coolant left, or its so low the system won't build any pressure.
Injuneer is online now
HectorM52
07-30-2017 11:46 AM
Biggiebound
04-21-2015 11:28 PM
KYWes
04-15-2015 07:28 PM
Blood type Z28
04-08-2015 11:34 PM
pologreen97z
12-02-2014 10:42 AM
Quick Reply: help water pump?
