96 Chevy Camaro Z28 - CamaroZ28.Com Message Board
Reply
Thread Tools Search this Thread
Old 03-11-2014, 07:29 PM   #1
96 Chevy Camaro Z28
I need help with my Camaro I was driving my car and it died it will crank over but will not start not getting any spark replaced the ICM but when you turn the key on it blows the ICM again at my wits end
sharon922 is offline   Reply With Quote
Old 03-11-2014, 08:45 PM   #2
parkers Z28's Avatar
Re: 96 Chevy Camaro Z28
It seems like someone else had the same problem a few months back ???
I think his problem was engine heat melted part of the wire harness ???
have you scanned for codes ??
parkers Z28 is offline   Reply With Quote
Old 03-11-2014, 08:55 PM   #3
Super Moderator
You posted this on two different forums. Problem is you have different info in the other post, indicating the "SECURITY" light came on a while back. Hard to get good responses when all the info isn't in one place. When I get back to my PC (on a phone right now) I'll merge the two threads to help you get a thorough response, based on all the info.
Injuneer is offline   Reply With Quote
Old 03-11-2014, 11:41 PM   #4
Maybe I should start over, I had drove my Camaro for years never a problem then the security light suddenly came on but it still started and ran fine. After a few months I was driving it, I parked outside a carwash, didn't take the car thru the car wash, just parked beside it, with it running, when I came out it acted like it was starving for fuel, (had a half tank) then it suddenly died and would crank but not start. I replaced the battery and nothing, still cranked but not start. Was getting no spark, so checked the ICM and it was blown replaced it but every time we turned on the key it would blow the ICM. We were told to replace the key, did that made no difference, still no spark and it still cranks over but will not start.
Old 03-12-2014, 09:26 AM   #5
Super Moderator
Basic questions, but they have to be asked:
Have you scanned it for codes?
Have you checked the fuel pressure?
Replacing the ignition key will not cure a blown fuse. You have to look at the other devices that are on the same circuit as the ICM - ignition coil and crankshaft position sensor.
Here's a way to check the coil, courtesy of Shoebox:
http://shbox.com/1/coil_testing.jpg
If the coil is OK, replace the fuse, and before turning the ignition to "start", pull the harness connector off the CKP sensor.
The "SECURITY" light comes on because a component in the system has failed, and the PCM is bypassing the security system. Again, refer to Shoebox's writeup:
4th Gen LT1 F-Body Tech-PassKey/VATS
Reply
Thread Thread Starter Forum Replies Last Post
NEWS: Motor Trend puts Chevy Camaro Z28 and Porsche 911 GT3 Head 2 Head NewsBot 2010 - 2015 Camaro News, Sightings, Pictures, and Multimedia 0 12-28-2014 07:20 PM
Complete the look of your Camaro with Racer Body Kit! CARiD Supporting Vendor Group Purchases and Sales 0 12-26-2014 05:20 AM
Horn won't shut off and security light is on fpete1992 General 1967-2002 F-Body Tech 1 12-11-2014 04:51 PM
Camaro Podcast #483 - Mustang finally tops Camaro in November ChrisFrez CamaroZ28.Com Podcast 2 12-07-2014 07:01 PM
NEWS: Mustang retakes monthly pony car sales crown from Camaro NewsBot 2010 - 2015 Camaro News, Sightings, Pictures, and Multimedia 0 12-03-2014 01:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
