95 Trans Am Ws6 Starts then dies
Old 03-06-2008, 01:36 AM
94Z2803Gt's Avatar
Ok so my buddy has a 95 trans am ws6 with the LT1, the car will start run for a few min, sometimes longer if you give it gas and then it will die. When it dies we try to restart the car and it doesnt start. Let it sit for a while it will start up again. The alternator is new, the battery is new, and the fuel filter is new. What are we missing? We need some insite so we can solve this problem. Please help us out
94Z2803Gt is offline
Old 03-06-2008, 08:38 AM
cnorton's Avatar
Put a fuel pressure gauge on it and be sure that the pump is maintaining pressure after the initial fire-up. If the pressure drops as the car dies, the pump is suspect.
c
cnorton is offline
Old 03-06-2008, 10:22 AM
powerslide350's Avatar
If the fuel pump checks out check the ICM located next to the coil on the drivers side head.
Maybe the car is just confused thinking its a WS6 and then just dies?
powerslide350 is offline
Old 03-06-2008, 11:14 AM
95camaro3800's Avatar
Does it misfire at all before it shuts off?
95camaro3800 is offline
Old 03-06-2008, 11:46 AM
94Z2803Gt's Avatar
No the car runs fines, then it suddenly just dies its really strange. It doesnt even sputter or sound likes its gonna die it just shuts off
Old 03-06-2008, 03:53 PM
maybe2fast's Avatar
security light on?
maybe2fast is offline
Old 03-06-2008, 04:21 PM
lilchrisgangsta's Avatar
does it have gas?
okay feel free to call me a dumbass.
lilchrisgangsta is offline
Old 03-07-2008, 12:03 PM
94Z2803Gt's Avatar
The security light is not on, and it has gas. We asked another opinion and they said it was prob the cam sensor so we are gonna look into that.
Old 03-07-2008, 12:15 PM
ss.slp.ls1's Avatar
As suggested earlier, did you get a fuel gauge on it yet? Test the ICM, coil, and do the spark test via shbox.com.
ss.slp.ls1 is offline
Old 03-07-2008, 07:39 PM
94Z2803Gt's Avatar
We are going to perform a fuel pressure test and a spark test this weekend ill let all ya know how the tests turn out.
Old 03-10-2008, 07:45 PM
jer4251's Avatar
im in the same pickle. my 97 SS starts(sometimes) and then dies out, and wont start. the 1st time it happened i got it started like 5 minutes later. the second timeit happaned(today) i moved the car and shut it down, went to move it back a while later, no start. still wont start for me. kinda pissing me off now.
let me know if you guys figure out your problem.
jer4251 is offline
Old 03-10-2008, 09:42 PM
94Z2803Gt's Avatar
we are pretty sure its the opti spark but we havent done the fuel pressure test yet either we are waiting til it gets a bit warmer here.
Old 03-10-2008, 09:50 PM
jer4251's Avatar
thats what im thinkin is worng with mine too. if its not a hard job i can use the one from my 96 SS thats just sittin in my garage. but its prob not that easy.
jer4251 is offline
Old 08-14-2008, 02:24 PM
z28_4life's Avatar
What if the security light was on would that be VATS shutting the car down?
z28_4life is offline
Old 07-10-2012, 10:56 AM
girlytech2010's Avatar
Re: 95 Trans Am Ws6 Starts then dies
I am having the same issue with my 95 z28. runs and drives fine then its almost like someone turned the key off. then wont start for a little while after. doesnt misfire or shutter what so ever idles perfect and no check engine light. this car seems to be a perfectly good running vehicle until it just shuts off.
NEW:
opti
plugs
wires
icm
coil
Battery
alternator
water pump
thermostat
fuel filter
tps
catalytic converter
RAN:
fuel pressure test 35-40 constant
i have spark on all 8 cylinders
im loosing my mind and a lot of money not being able to figure this out
girlytech2010 is offline
Quick Reply: 95 Trans Am Ws6 Starts then dies
