95 LT1 service engine soon light
The light comes on when I start to drive in less than a mile. I know it has a OBD 1, but is there a way to have it diagnosed, it runs great but it is annoying. thanks. Also the brake and ABS inop light is on all the time, but when I move, the low trac light flashes and i here a click with the light under the hood, any ideas on that one, thanks again.
Most auto parts stores are unable to pull codes from a '95, because of it being OBDI with the OBDII port. You'll have to find a friend with the proper code reader/scan tool, or go to a garage. As far as the brake/ABS light, that will entail a trip to a garage anyway.
mspennyhughes
11-28-2014 03:22 PM
