94 throttle cable
94 throttle cable
I've had my TB off for a few weeks and now both cable have slack. I've heard there is no way to adjust it on cars without traction control... So what is the best fix for this? Sorry if this has been covered already, I cant seem to find an answer.
Re: 94 throttle cable
If you are using the same cables, they are mounted in the black bracket that attaches to the intake manifold the correct way, the cables are connected to the quadrant correctly, and you changed nothing on the throttle body, it's hard to understand how slack could develop.
ill try to upload some pics soon. the only thing different is the 52mm throttle body.
EDIT: The TB was installed before I had the car. Im not sure how long its been loose.
08-24-2015 06:41 AM
detroitmuscle
07-31-2015 04:21 AM
88IROC_Z
07-22-2015 11:38 PM
