Pahntom LEak
Old 12-17-2005, 09:59 AM
TPG013's Avatar
Pahntom LEak
Newbie here. I have a '97 Z28 and I am getting a strong coolnat smell after it's been driven awhile and I open the hood. Everything is bone dry. Any ideas where the smell might be coming from?
Can it bad a bad radiator cap? That's where the smell seems strongest.
TPG013 is offline
Old 12-17-2005, 12:12 PM
moparman's Avatar
Re: Pahntom LEak
It could be the cap. Also, check the plastic tank on the passenger side of the radiator for a crack. You may need to pressurize the radiator to find the leak.
moparman is offline
Old 12-18-2005, 10:36 AM
pHEnomIC's Avatar
Re: Pahntom LEak
If you still have the stock radiator cap, you should replace it. Mine wasn't holding any pressure and was leaking a lot. Like moparman said. The bearing in the water pump has a tendency to leak, it will usually wet random things under the bay and will come from behind the pump. Check your oil to make sure it isn't frothy, that could indicate a blown headgasket.
pHEnomIC is offline
Old 12-18-2005, 11:59 AM
lr383's Avatar
Re: Pahntom LEak
Also check the tanks on both sides of your radiator. Sometimes they have hair lines cracks that start leaking. Does it get a little warming than normal?
lr383 is offline
Old 12-18-2005, 12:08 PM
RICEFEDZ28's Avatar
Re: Pahntom LEak
Hows your coolant level? Most common place is the weep hole under the water pump. Look from under the car with a light.
RICEFEDZ28 is offline
Old 12-19-2005, 08:49 AM
TPG013's Avatar
Re: Pahntom LEak
Thanks for all the advice.
Oil is fine so I'm ruling out head gasket. The water pump was replaced about a yesr or so ago, so I'm thinkiong it's not that either. It runs nice and cooland the coolant level is up that's what's so confusing to me. In addition the low coolant light came on yesterday, but the level is fine. I did a search and found that the sensor seems to be a popular thing to go bad so I'll replace that and see what happens.
TPG013 is offline
Jeff1904
06-05-2016 05:00 PM
magman
04-15-2016 03:08 AM
blac94Z
11-04-2015 01:59 PM
drt
09-27-2015 04:39 PM
colts0455
09-27-2015 01:07 PM
Quick Reply: Pahntom LEak
