Guestion about balancing my engine
Old 08-02-2010, 05:28 PM
hughett17's Avatar
Question Guestion about balancing my engine
ive got a 94 z28 just had the engine rebuild. it now has srp 2 valve relief pistons that are 30 over and eagle i beam rods with total seal rings. and the crank turned 20/20. ok heres the question ...the machine shop that done the work dint balace my motor ..they said i dint tell them to ..do i need to be worried about if messing up or should my parts that i used for the rebuild be close to stock balance ? the motor has a cc306 cam and c/r of about 11.5 or more .... its not a race car but i do want to run it hard when i need to take out that mustang thats talkin **** ...lol...it will (maybe if the engines ok) see nitrous...thanks
hughett17 is offline
Old 08-02-2010, 05:32 PM
RamAir95TA's Avatar
Oh boy...I don't even know where to start.
If you want the motor to last, it needs to be balanced.
RamAir95TA is offline
Old 08-02-2010, 05:49 PM
dangalla's Avatar
when you take it back apart to have it balanced you should take it to a different shop that knows what they are doing
dangalla is offline
Old 08-02-2010, 06:05 PM
hughett17's Avatar
ya i agree 100 % but its already in and its running very strong for now , its took me almost a year to get this thing going i dont have the time or money to have it redone ....ticking time bomb ...just my luck
Old 08-02-2010, 08:51 PM
MachinistOne's Avatar
Please!
I cannot believe that the shop did not inform you that balancing was necessary when changing all those components. Sounds like some cob-it-together hack shop that you should never go back to.
MachinistOne is offline
Old 08-02-2010, 09:48 PM
hughett17's Avatar
trust me i wont be back.im gonna call them tomorro and let them no that they wont get away with doin me like that i will ruin theyre buisness ...just hope it holds together till winter time
Old 08-03-2010, 08:07 PM
Well....I wouldn't go so far as to threaten to ruin their business.
Old 08-04-2010, 05:34 PM
hughett17's Avatar
no just my buisness and all my friends , which is a lot of ppl ....it may be ok for a while im just gonna wait and see what happends
Old 08-04-2010, 06:19 PM
brucer's Avatar
might put a good balancer on it, if you havent already..
brucer is offline
Old 08-04-2010, 06:26 PM
Kevin Blown 95 TA's Avatar
Does it shake or vibrate noticeably?
Kevin Blown 95 TA is offline
Old 08-04-2010, 07:46 PM
hughett17's Avatar
the vibration is noticable but its not that bad , and if i were to try a balancer which one would be best?
Old 08-04-2010, 08:16 PM
RamAir95TA's Avatar
An aftermarket balancer won't really help all that much at this point.
Old 08-04-2010, 10:37 PM
brucer's Avatar
if it has a noticeable vibration, a balancer isnt gonna help..
you really need to tear it apart and get the crankshaft balanced..
an unbalanced engine puts a lot of unneeded force on bearings.. not to mention it can prematurely wear about every component in an engine...
brucer is offline
HectorM52
07-30-2017 11:46 AM
Jason Short
01-19-2015 06:33 PM
1996LT1Z28
12-01-2014 01:01 AM
Nostang 96z
09-15-2002 10:15 PM
Quick Reply: Guestion about balancing my engine
