93 Z-28 just shut off going down road.
Old 04-08-2003, 01:37 PM
93SS's Avatar
I had just filled up at the chevron gas station. App. 1 mile from station and close to home , engine quit running. I had been driving app 40 mph. Have auto trans. Put trans in neutral and coasted off side of road at a wide area. Turned off lights and key. Put trans in park and turned key. Engine started right up and ran app. 2-3 seconds. Then shut off. Restarted engine rightup. Ran again and gave some gas, ran app 3-4 seconds, then shut down. Did that several times and engine would just shut off. Called wife to bring laptop with diacom in it. Waited app 10-15 min. It had just started drizzing rain . Well, when wife arrived ,laptop battery was dead. Opened hood and moved coil wire some at the opti end. Started up engine, and it ran for several minutes. So I tried to make it home ,which I did. Charged laptop battery. Next day checked computer. Showed a #16 Low resalution pulse code. Engine was running in garage ok. Shut off, cleared code with diacom. Restarted engine fine . Everything looks ok on diacom. I need some advice on what to do. Opti has been replaced in early 97. Only app 30,000 miles on opti. car kept in garage. I have replaced coil and plugwire with MSD app 2 years ago. Now I don't trust car to go out in , Help. Thanks.
93SS is offline
Old 04-08-2003, 01:43 PM
94 CAMRO Z28's Avatar
Mine did the exact same thing a year ago. I tried a new coil, ignition control module, etc. It ended up being a full tank of bad gas. I dont know if there was water in it or what but it was running fine and then shut shut right off. Started right back up, ran for 5 min. or so, shut off, start up, shut off. Also it seemed to be down on power and sounded ruff. I went through about 2/3 tank of fuel, refilled and the car seemed to be a ton better, burnt that tank away to nothing and refilled again and it was all better.
Aaron
94 CAMRO Z28 is offline
IDOXLR8's Avatar
Sorry to say but it sounds like a bad opti.
IDOXLR8 is offline
IndyZman
10-22-2015 02:17 PM
68camaroboltz
10-05-2015 01:46 PM
KYWes
09-26-2015 08:49 AM
rvonsternberg
09-14-2015 11:58 AM
heus
09-08-2015 12:01 PM
Quick Reply: 93 Z-28 just shut off going down road.
